Light comes on; no accelerator pedal response - Ford Powerstroke Diesel Forum
Old 07-09-2009, 07:32 AM
Lately my 2002 7.3 will show engine light and no accelerator response. Engine does not die though. I can pump pedal a few times, then normal, then back to problem. Any suggestions?
Old 07-09-2009, 08:06 AM
Throttle position sensor. If it goes bad, or the PCM sees no signal from it, it will allow only idle. Check wiring. Pull codes, if that is it, replace.
Old 07-09-2009, 08:53 AM
Thank you for your post. About how much is a throttle position sensor? Where is it? And is it something I can change out myself? (I am pretty mechanically inclined)
Old 07-09-2009, 08:57 AM
ADMIN AND TECH
agreed , thats probably your problem, the tps is mounted on the pedal assembly
