Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
  #11 (permalink)
Old 07-01-2009, 08:25 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
Don't make me drive down there.......
you best get your happy azz on the road!
  #12 (permalink)
Old 07-01-2009, 08:32 PM
KeepinItFord KeepinItFord is offline
Isnt there just a bolt that hold the tube in? that how it is on my stang. u just unbolt the tube and u can pull it out try to look where the tube meets the engine if u can see in there. Sorry if this is wrong or u already tried this. just throwin stuff out there.
  #13 (permalink)
Old 07-01-2009, 08:52 PM
95superstroke 95superstroke is offline
I've seen guys cut the cross member out, take the pan off and weld the cross member back together. Or you could just slap some duct tape over the hole and call it good
  #14 (permalink)
Old 07-01-2009, 09:09 PM
the tube does bolt to the valve cover. you can remove that and pull the tube out. The problem I am having is where the tube goes into the oil pan. some genius decided to make that removable from the pan, but the thing is that it is 2 pieces. A nut on the outside and another piece on the inside. well if that inside piece falls into the oil pan you are screwed.......
Thanks to Dirk I think I have a handle on the situation. Will update once I get it completed hopefully tomorrow.
  #15 (permalink)
Old 07-01-2009, 09:28 PM
Dirk Dirk is offline
Diesel Innovations
Easy peasy.
  #16 (permalink)
Old 07-01-2009, 09:43 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
Dirk is going to leave us all hanging on the fix?
  #17 (permalink)
Old 07-01-2009, 11:03 PM
Diesel Innovations
Yes...............
  #18 (permalink)
Old 07-01-2009, 11:04 PM
Diesel Innovations
John can post the fix if this works..
  #19 (permalink)
Old 07-01-2009, 11:31 PM
DunesRunner08 DunesRunner08 is offline
one of those long skinny collapsable magnets.... ?????? I dunno..
  #20 (permalink)
Old 07-01-2009, 11:49 PM
toddy toddy is offline
OperationSmile.org
John I got a really easy fix for you. Just give it to me....
