Fuel Leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-28-2009, 09:30 AM Thread Starter
Fuel Leak
Hi Everyone,
I need some help. I have a 2003 7.3 E350 Van. As with everything on this van it's almost impossible to get to anything. I developed a fuel leak. It appears to be coming down the back of the motor and leaking over the starter. I also think I have fuel getting into the oil. I've seen posts about the valley filling up from bad o rings on the separator drain but don't know how to get to it. Also, I read that the injection pump could cause fuel leaks and oil diluting. How big of a job is this and how long do you think it would take? I use my van everyday for work and can't afford to be without it.
Thanks,
Jim
High Mileage Jim is offline
post #2 of 7 Old 07-11-2009, 03:34 PM Thread Starter
Thumbs down
33 hits with no response? Thanks for the non-help.
post #3 of 7 Old 07-11-2009, 03:48 PM
Quoted: 5 Post(s)
now thats not cool man, not everybody who happens upon this thread will not know how to help.
As far as working on the van, yes everything is a pain to get to. The filter bowl drain valve orings probably need to be replaced, and you just have to grin and bear it to get to them. there is a write up floating around here somewhere on it......look under 7.3 repair help section. Your other possibilities are leaky feul lines around your filter bowl.......
Your engine has no injection pump, each injector is sorta like it's own pump.....google HEUI injection and you'll figure it out. Are you getting lots of fuel in your oil, or does it just smell a little like diesel? Is the truck running rough or smoking??
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #4 of 7 Old 07-11-2009, 03:48 PM
97 golden stroker's Avatar
I dont think many people on this site have wroked on a van. but if you take the dog house off you shoul be able to see a little better. the nice thing about diesel vs gas diesel will not dry up so you will have a better idea of the leak. I have seen dozens of the fuel bowl drans leak like you said. but with out looking at it i cant tell the time. you may be able to pull it off without pulling the fuel bowl but dont know for sure good luck man.
97
afe intake
ats intercooler
3in. down pipe to 4in str8
fpr shim
terminator hpop
warm up valve delete
tw 6 position
southbend clutch
Stage ones from Rosewood diesel
SD IDM
d66
12000k hid dual element
thinking real hard about a nozzle upgrade
220k
97 golden stroker is offline
post #5 of 7 Old 07-11-2009, 04:57 PM Thread Starter
Ianstew,
You're right. That wasn't cool. But after 2 weeks I was very frustrated finding this problem and hoped I might get some help on this forum. I've fixed the external leak. It was not the separator or the drain. The problem was the fuel line that runs over the top of the engine had a split it it directly under the clamp, impossible to see due to the location under the turbo and under the windshield and cowl.
The fuel in the oil is a very small amount. It does run rough on start up but after it warms up it's as smooth as the day I bought it. I'll keep reserching it.
Jim
post #6 of 7 Old 07-11-2009, 05:17 PM
Quoted: 5 Post(s)
Originally Posted by High Mileage Jim View Post
Ianstew,
Jim
If it's a small amount, you are probably getting some blow by with worn rings, scored cylinders, etc. I bet you've got pretty high miles......
ianstew is offline
post #7 of 7 Old 07-11-2009, 05:17 PM
I happened to read the other thread you posted in ("E series owner"), so I happen to know that you have a 2003 7.3l van. There are a few things that can leak fuel on top of that engine. There are 4 lines that go in or out of the fuel bowl, the fuel drain, the lines that go to the heads. With the lines that go to the heads, there is the possibility that the lines them selves will wear through where the clamps hold them down. Passenger side runs under the turbo to the back. The driver's side runs to the front of the head under the air conditioner compressor / power steering /vacuum pump bracket. To get to this one, I would suggest unbolting the A/C compressor and moving it out to the side. Then unbolt the actual bracket. I think it holds on with 3 long bolts, and you can loosten them all and move the bracket to the outside a ways. You don't have to remove the vacuum pump or PS pump from the bracket, I don't think.
The final thing that can leak is the connections to the heads. The washers there are made of the same stuff as the ones that leak on the fuel bowl. The theory is that the new ULSD fuel eats away at the o-rings and washers. The other theory is that they are 6 years old, and it's just the life time of the rubber compound. I would go to Replacement O-rings for Diesel Engines and get a kit with all the parts you need to do the entire top-end fuel system. At 700K it's about time.
The fuel in the oil is probably due to the age and mileage of your injectors. They are driven by oil pressure, and they also contain fuel. When they wear, I believe that you can intermix some fuel and oil. It could also be the injector o-rings.
Eli Benson - EMT, Ambulance Mechanic
'08 F350 Dually KR - Spartan'd
'07 F250 CC SB 4x4 XLT - SCT /w Innovative Tunes
4 '09 & '10 E350 6.0l ambulances
1 '08 Duramax 6.6 (LMM) van ambulance
elibenson is offline
