Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 06-27-2009, 03:46 PM
dvltoy dvltoy is offline
code p1396
my truck keeps coming up with this code and i can't find anything about it does any one knows what it means it comes up as p1396 unknow
Old 06-27-2009, 03:58 PM
jamstoyz jamstoyz is offline
dtc's left bank what ever that means. check this site out.
7.3 power st trouble code list
Old 06-27-2009, 03:59 PM
code p1396
my truck keeps coming up with this code and i can't find anything about it does any one knows what it means it comes up as p1396 unknown
Old 06-27-2009, 04:02 PM
thank you i will check it out
korterman1 korterman1 is offline
glow plug monitor fault bank # 2. good luck with that.
Old 06-27-2009, 05:36 PM
billelf123 billelf123 is offline
P1396 Glow Plug Monitor Fault Bank No. 2
Old 06-27-2009, 05:41 PM
Found a list of codes on this site, scroll to the bottom of the page!
Welcome to guzzle's Ford PSD Web Pages
Old 07-03-2009, 03:04 PM
Banshee34 Banshee34 is offline
Hey guys Dvl is actually my brother-in-law and some more specifics would really help out. This is his first diesel and I'm no tech.
Old 07-06-2009, 01:38 PM
bdurrant bdurrant is offline
Whats happening is the glow plug control module is either seeing less than 32 amps pull on the left bank or that the difference between the left bank and right banks is more than 8.5 amps. there are connectors at the base of the valve cover toward the engine valley. they have seven pins in them. you want to test the outside two pins on the front and rear of the connector. they will have either yellow or brown wires. I would ohm out the glow plugs on the left bank first. they should not read more than 2 ohms. If one of them is, then either the under valve cover harness has high resistance or that glow plug has high resistance which either would need to be replaced. if the left banks is all ok then test the right bank but you want to see if any are shorted out. if any read less than about .5 ohms than either the uvch or the glow plug is shorted out. If you have any questions about how to test, let me know. sorry if this is confusing, i have a hard time putting actions to words. lol
