Compression Test - Can you do with cold engine? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-25-2009, 06:01 AM Thread Starter
Can you do a compression test with a cold engine?
I know hot is the norm but roughly how much PSI difference?
I just need to find the problem cylinder, have suspect rockarm/pushrod issue. Not really that concerned with the exact pressure readings right now.
Since valve covers are already off, really can't warm it up. Also, would have to put back together to do Contribution Test, so trying to avoid that.
Truck is '00 7.3 F350.
Edit 6-29-09: You may need a Mityvac "Powerstroke glow plug adapter" MVA5605 to mate up to your compression test hose. If you have a cheaper diesel compression test kit, chances are there won't be a fitting with enough reach for the Powerstroke, this one is made for it.
Edit 7-6-09: Joke is on me, above adapter will only work with a Mityvac coupler, can't take it apart and refit it to work either...took back my Harbor Freight diesel compression test kit ($26) and getting Mityvac MV5534 ($76 + shipping) which is their diesel gage, hose and coupler only kit, without adapters. Bad thing is I bet the Mityvac is made in China too, plus I hate doing anything to add more $ to help Obama's joke economic "recovery" spending/debt plan.
2000 F350 PSD/Auto, 4x4, Crew/Short, White
290k miles
ITP Hutch Mod Kit
Donaldson Air Filter Kit
Predator Zoodad
Long Lead #8 Injector
KCM HPX Tube
Monroe Reflex Shocks
Scangauge II
Gray M'Craft CPS
(Black BWD CPS from O'Reilly's went bad)
New Version ICP Sensor
New EBP Sensor
bob00stroke is offline
post #2 of 4 Old 06-25-2009, 06:43 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
you can do a test with a cold motor, PSI difference might be 2-3% form warm. you dont need to put the VC back on to do a contribution test, put injectors and GP in to get it running...
post #3 of 4 Old 06-25-2009, 10:26 AM Thread Starter
Thanks for the quick info.
That's a cool panel for gauges/switches you have in that Excursion pic.
290k miles
ITP Hutch Mod Kit
Predator Zoodad
KCM HPX Tube
Scangauge II
Gray M'Craft CPS
New EBP Sensor
post #4 of 4 Old 06-25-2009, 11:30 AM
wriott
Guest
Posts: n/a
Quoted: Post(s)
its not mine its another members on here, cant remember who. i just ordered the panel and going to be customizing it sorta like that one
