Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 06-16-2009, 04:48 AM
MassStroker4 MassStroker4 is offline
The noise is killing me!
My front axle is also grinding however i just replaced both of my wheel bearings and ball joints to eliminate that , is there such thing as an Axle bearing?
Old 06-16-2009, 04:52 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
There are bearings inside the differential. But unless your hubs are locked up. Or unless your in 4wd you should not have that spinning.
Check the u-joints on the front axle. Also check the brakes.
Old 06-16-2009, 04:58 AM
KLUSTER KLUSTER is offline
THERE IS OUTER AXLE BERINGS, ALSO CARRIER BERINGS THAT THE RING GEAR IS BOLTED TO,THAT THE SPLINED END OF THE AXLE RIDES IN. ARE YOU SURE YOUR HUBS ARE NOT THE CULPRIT, TO THE GRINDING? IF THERE TAKING A S**T , THEY WILL START DETERIORATING RAPIDLY. HOW OLD IS THE TRUCK , WERE YOU RECENTLY IN THE MUD ??
Old 06-16-2009, 05:01 AM
wriott wriott is offline
BUILT & BROKE BY ME
dust shields might be draggin. you calipers might not be releasing all the way
Old 06-16-2009, 09:01 PM
i had the hubs locked unknowingly for a while and the truck was not in four wheel drive. could this be the culprit?
