Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 06-10-2009, 04:52 PM
matthewdlouhy matthewdlouhy is offline
Question 4x4 Low Range Will Not Engage
I checked the fuses and swaped relays. 4x4 high works fine. Put it in neutral and press the brake and flip to 4x4 low range and Nothing no light or anything. The lights do come on when starting though. Please offer some help. Thanks.
Old 06-24-2009, 03:14 PM
mrgrimm mrgrimm is offline
hmmm, dunno but maybe the actuator is bad. It's probably a box of somekind on the t-case with a plug going to it...check to see if it's getting voltage, if it is and it's still not engaging then that that might be your problem?
