Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 06-08-2009, 06:01 PM
ABoyAndHisToys ABoyAndHisToys is offline
Send a message via AIM to ABoyAndHisToys
Front axel is grinding HELP!!
On the way home from the Pocono Race today I started hearing a squeal. Stopped to eat and in the parking lot it seemed to bind up and make a clanking noise when moving slowly. I get home and tear into it thinking it was the hub bearing but they look good. I'm thinking axel bearing. Has anyone changed them before? Is there a write up?Also I took some video and I'm not sure if my axel is supposed to move this much. Is it? Help guys...I need to get to work tommorrow.
Old 06-08-2009, 06:06 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
I could not tell from the vid but is that movement possibly coming from the U-joint!
Old 06-08-2009, 06:09 PM
The whole shaft moves around. Yes also at the u-joint. I just cant tell where the grinding is coming from.
Old 06-08-2009, 06:11 PM
Heavy Equipment 911
What does the chunk look like. Any shavings?
Old 06-08-2009, 06:14 PM
There are shaving on the top of the hub assembly. Is there a bearing where the axel comes thru?
Old 06-08-2009, 06:19 PM
Heavy Equipment 911
Just a side question, what do your brakes look like!
Old 06-08-2009, 06:20 PM
Fine... It was my first thought. If my brakes were mangled I would have said hub bearing.
Old 06-08-2009, 06:29 PM
Heavy Equipment 911
Well, will the axel spin or is it bound up with the front tires off the ground!
Old 06-08-2009, 06:32 PM
bockhold bockhold is offline
lʍǝʞs poɯ 2 oƃ ʇupıp ɔıɹǝ
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
i would think bearings
Old 06-08-2009, 06:34 PM
Heavy Equipment 911
I think it may be too but I want to make sure the bearings in the chunk are ok first!
