Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #11 (permalink)
Old 06-08-2009, 07:23 PM
ABoyAndHisToys ABoyAndHisToys is offline
Send a message via AIM to ABoyAndHisToys
Well.... I feel stupid!!!! I went back out and got my head straight. It's kinda hard after being drunk since Thursday at the track.... I realized my hub was on free.... My axle isnt even spinning ....... It is in fact my hub assembly... I need the truck so it looks like either Autozone or the Ford House. It kills me because there is a site that has both sides cheaper than AZ wants for one. Thanks Guys!!!!
  #12 (permalink)
Old 06-08-2009, 07:26 PM
1999nj73 1999nj73 is offline
Sounds like the Hub assembly..I am in the middle of replacing one right now on driver side.Auto Zone 315.00 Timken item 515020
  #13 (permalink)
Old 06-08-2009, 07:28 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
I dont suppose that you have time for an ebay set!
  #14 (permalink)
Old 06-09-2009, 07:28 AM
Anyone know how to tell if its 4wheel antilock? I dont have sensors going to my rear.
  #15 (permalink)
Old 06-09-2009, 01:04 PM
Heavy Equipment 911
I am sure it is being an '01!
  #16 (permalink)
Old 06-09-2009, 01:09 PM
bockhold bockhold is offline
ssɐlɔ uıɥɔɐǝʇ pǝlıɐɟ ɔıɹǝ
Send a message via AIM to bockhold Send a message via MSN to bockhold Send a message via Yahoo to bockhold
i think 99 was the last with no front abs
  #17 (permalink)
Old 06-10-2009, 01:15 PM
Well it was the hub assembly.... Ford wanted 438.00....AZ 389.00.... My local mom and pop.... 267.00 delivered to my house. Back up and running .... Thanks again guys!!!
  #18 (permalink)
Old 06-15-2009, 03:32 PM
PatDoody PatDoody is offline
Send a message via AIM to PatDoody
My truck is doing the same thing, its intermittent, usually when I hit a bump itll start grinding then when I hit another bump it will go away... I can also feel a "lumpy" spot in my steering sometimes like its geting hung up... You guys think its the same thing?
  #19 (permalink)
Old 06-16-2009, 06:06 AM
Jack up the wheel in question and remove the tire. Make sure your hub is not engaged and turn the hub assembly. If it grinds you found your issue. Also shake it around a bit looking for movement
  #20 (permalink)
Old 07-09-2009, 10:38 PM
Austinj427 Austinj427 is offline
I have the same problem as described. The only problem is I can feel it under my left foot at certain times and the left hub is brand new..
