brake vibration
I have a 2000 7.3 PS 4x4 SC SB with 77,000 miles on it. Recently, the truck has started to shake when I use the brakes. It feels like the front end the way that the steering wheel shakes. I had the front rotors turned and new pads installed about 2000 miles ago, along with a new lower right ball joint and new right wheel studs. Any ideas? Thanks!
Mine does the same thing, and its a warped rotor. Your problem sounds exactly like mine.
also.....most shops dont, but hand torque each of your lugnuts.....fords newest spec on the lugnuts on superduties is 150ft lbs. torqueing a wheel actually reduces the chance that a rotor will warp. |
It's nice to have you around Marc. As always, good info, keep it coming!
Thanks for the help guys, I'll have to get it checked out.
Make sure they didn't machine them under spec too, if they did then send it right back to them and make them replace the rotors.
