Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #21 (permalink)
Old 09-11-2009, 10:41 AM
Tony V Tony V is offline
Sweet Diesel Smell
A wheel bearing could affect the steering if it is going out.
  #22 (permalink)
Old 09-14-2009, 09:48 PM
WA.Ranger WA.Ranger is offline
X2!
On a side note about-To check for play, I had one of my sons (9) sit in the drivers seat with the steering wheel unlocked and had him turn it back and forth. I wound up having play in my steering box which has since been remidied with a Red-Head.
  #23 (permalink)
Old 09-15-2009, 05:45 PM
fleastang fleastang is offline
Originally Posted by WA.Ranger View Post
X2!
x2 on the Red-Head steering box!! Good product!!
  #24 (permalink)
Old 09-16-2009, 07:16 PM
Jesse Lambert Jesse Lambert is offline
Are the hub bearing assemblies on the early 99's differant? The ebay ads look like they are for 3/99 and later
  #25 (permalink)
Old 09-17-2009, 07:13 AM
Sweet Diesel Smell
Whats this red head steering box?
  #26 (permalink)
Old 09-17-2009, 07:25 AM
In my opinion, one of the best mods I've ever done to my truck. You can call them and talk to Harvey, he'll tell you everything he does to his box to make them that way.
Red-Head Steering Gears, Seattle WA - Red-Head Steering Gears Home
  #27 (permalink)
Old 09-17-2009, 07:32 AM
Sweet Diesel Smell
Thanks i'll look into this for sure
  #28 (permalink)
Old 09-17-2009, 07:37 AM
Dave Dave is offline
Obama sucks
Originally Posted by my19997.3 View Post
If you're use to any type of wrenching, then this isn't too much. If you know the hub is bad, then the replacement will have the needle bearings with it. Mine had a bad u-joint which took out the needle bearings and then the hub. Here's about the easiest way to put it:
1 - all prep stuff (e-brake, jack, jack stands, etc)
2 - Remove wheel
3 - remove c-ring for hub locker
4 - remove hub locker
5 - remove c-clip and washers (inside the hub, behind the hub locker)
6 - Remove caliper, bracket, pads, and rotor disconnect abs wire (if equipped)
7 - there are 4 bolt studs behind the hub, remove all four (may need to move the axle a little to get better access to the nuts
8 - once studs are removed, pull hub off
9 - I used a wire brush to clean everything up before installing the new
10 - install in reverse
If you have any questions while you're doing it (just did mine 2 weeks ago), PM me and I'll send you my cell number to help you
Other than the method shown to pull the lock out hub. is the process the same for the 05 up trucks?
  #29 (permalink)
Old 10-06-2009, 07:31 AM
my19997.3 my19997.3 is offline
Dave, I'm not sure about this. This weekend I'll have my buddy bring his '06 over so we can tear it apart. I'll try to provide aniother write-up on it
  #30 (permalink)
Old 10-06-2009, 07:50 AM
chefmatthew chefmatthew is offline
I am new here and haven't posted anything yet but I just replaced my hub assembly on my 2000 f350 and it was the easiest front bearings that I have ever done. I bought mine at autopartsdirecttoyou.com. They offer a good warranty and were less than $200.00 each. I also purchased a vacuum pump from them that was broken when I got it, I called and they sent a new one out that day. They told me to throw the other one away. Just some thoughts.
Also my locking hubs were froze up as well. Warn Premium are great.
