Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #11 (permalink)
Old 03-30-2009, 07:16 PM
my19997.3 my19997.3 is offline
Originally Posted by DieselFam View Post
I was just going to ask the same question. I need front axle bearings for my EX. I saw on one site that they are listed as Timken Bearings. I need a part number to make sure its the right one. Any help would be appreciated. Thanks.
Just to make sure.... are you looking for the hub bearing assembly or just the needle bearings that press into the back side where the stub axle slides in at?
  #12 (permalink)
Old 03-30-2009, 07:43 PM
WHOSNXT WHOSNXT is offline
I guess the whole thing cause I dont know whats bad I assume what your talking about comes with the whole unit? Also what all is involved do you have to have any special tools like Impact or anything and can the average joe put one in? Is there a wright up on here anywhere that explains how to do it like there is alot of other repair if so I couldnt find it? thanks
  #13 (permalink)
Old 03-30-2009, 07:53 PM
If you're use to any type of wrenching, then this isn't too much. If you know the hub is bad, then the replacement will have the needle bearings with it. Mine had a bad u-joint which took out the needle bearings and then the hub. Here's about the easiest way to put it:
1 - all prep stuff (e-brake, jack, jack stands, etc)
2 - Remove wheel
3 - remove c-ring for hub locker
4 - remove hub locker
5 - remove c-clip and washers (inside the hub, behind the hub locker)
6 - Remove caliper, bracket, pads, and rotor disconnect abs wire (if equipped)
7 - there are 4 bolt studs behind the hub, remove all four (may need to move the axle a little to get better access to the nuts
8 - once studs are removed, pull hub off
9 - I used a wire brush to clean everything up before installing the new
10 - install in reverse
If you have any questions while you're doing it (just did mine 2 weeks ago), PM me and I'll send you my cell number to help you
  #14 (permalink)
Old 03-30-2009, 07:55 PM
sorry, forgot that, I did everything with regular hand tools (a breaker bar every now and then)
  #15 (permalink)
Old 03-30-2009, 08:49 PM
2 - Remove wheel
Thanks alot It sounds like I could do it I hope im sure it sounds easier than it is. but I need to change it out its roaring more and more each day and making a light popping noise also.
  #16 (permalink)
Old 03-31-2009, 07:56 AM
DieselFam DieselFam is offline
I'm not for sure on this, but that may be a hub problem. Especially if it is popping. Mine was popping a little and the hub was frozen in the auto position. I replaced the hub (both sides) with Warn Premium and the popping went away. I wish I would have gone ahead and replaced the bearing assembly while I was at it. It seems to be leaking a little oil out of the axle housing now. So while I address that I'm upgrading the whole damn thing.
  #17 (permalink)
Old 03-31-2009, 04:21 PM
im pretty sure its the bearings cause its roaring and making a noise it may be more like a little grinding also but kinda sounds like a suddle popping noise to? my friend which is a diesel mechanic told me it was bearing but that might be just from sound of it plus he had it off the ground on lift while changing all the fluids.
  #18 (permalink)
Old 03-31-2009, 04:26 PM
Austinj427 Austinj427 is offline
Leon, Do you know if bad bearings will affect play in the steering wheel at all?
  #19 (permalink)
Old 04-02-2009, 05:23 PM
Not really sure about the steering. I know when my bearing went out, it would make a bang sound when I would make a sharp turn. When going straight (cruising) the steering wheel would "flutter" a little bit if I would let my hand off the wheel you could see if moving. Describe what play you have in the wheel.
  #20 (permalink)
Old 09-11-2009, 07:43 AM
hntwhitetail hntwhitetail is offline
2 - Remove wheel
Real good write up.
