Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 03-09-2009, 03:47 PM
jesilvas jesilvas is offline
Replacing carrier bearing
i guess this is in the right forum
so i got my new carrier bearing for the driveshaft and was wondering how to replace it
i'm guessing i gotta remove the driveshaft
what i don't know is from what part.
ideas a always welcome
pictures are even better but not a necessity
thanks
Old 03-09-2009, 04:00 PM
fordpwrstroke7 fordpwrstroke7 is offline
You don't have to remove the driveshaft. There are a couple of stock nuts you have to take off. It is very straight forward and shouldn't take more than 10 minutes to do. I don't have pics but I did mine in about 5 minutes. Look at the stock one and you'll see a couple of nuts that have to come off to get the bracket out. You might want to get a jack to support the driveshaft while you do it.
Old 03-09-2009, 04:04 PM
really? because i thought you had to slip the metal sleeve around the shaft?
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Ok how did you press the carrier bearing off. You have to remove the driveshaft. There is no other way to do it.
Remove the driveshaft, press the bearing off and press the new one on. This ensures the driveshaft stays in balance.
Old 03-09-2009, 04:07 PM
which end of the drive shaft do you remove?
Old 03-09-2009, 04:09 PM
I guess I read your post too quickly...I thought you were talking about a carrier bearing DROP BRACKET, not the carrier bearing itself. Sorry for the useless advice.
Old 03-09-2009, 04:43 PM
it's cool. i ignored it anyway
Old 03-10-2009, 05:13 PM
Chamberlain79 Chamberlain79 is offline
On my 01 crew cab short bed 4x4 I removed the front 1/2 of the rear drive shaft from the truck. Their are two bolts for the bearing mount that that have to come out The u-joint bolts are 8mm and the flange to transfer case bolts are 12mm 12 point. Once you have it out their is a nut holding the yoke on be care removing it the threads stripped out of the nut on mine . Remove the nut and the bearing will slide of it is not pressed on. Install new one and reinstall the shaft. Hopes this helps.
Old 03-10-2009, 05:15 PM
oh ok so there is just a nut holding the yoke on?
ok good. wasn't sure if it was something more irritating
