- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
how old are your tires? You would be suprised how many cars/trucks come in the shop asking for alignments and tire balances when really they just have seperated belts in the tires. With the truck off the ground spin each wheel as fast as you can an hold your hand over the tread. Its should be pretty smooth, any irregularites in the tread could be the beginings of belt seperation...your symptoms are dead on what happens when tires do this. Go ahead an replace the front end parts if you know they are bad though...count on paying $60+ for an alignment after all that. |
| Sponsored Links |
just replace the little white washer on the high pressure power steering hose!!!you will need to get it from ford and it will look to small.. you need to soak the washer in hot water and its a royal pain in the a$$ to get it over the end of the hose!!!also dont let the steering wheel turn while the box is disconnected otherwise you'll be buying a clock spring!!
i got that same problem, right under my feet, replaced the ball joints and the steering box because that was needed anyways, all the front steering components are tight as can be. wheel bearings are also perfect
there was a thread around here where the guy replaced all the sway bar bolts with larger ones and it cured the rattle/clunking. he mentioned that the bushings were new and still clunking right under the drivers side floor board |
| Sponsored Links |
