Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #11 (permalink)
Old 02-15-2009, 02:13 PM
OregonStroker OregonStroker is offline
the steering shaft is rubber mounted, i believe. should be able to move a little bit. i could be wrong.
  #12 (permalink)
Old 02-15-2009, 02:15 PM
n20 n20 is offline
Do i need to jack the tires of the ground to check the wheel bearings?
  #13 (permalink)
Old 02-15-2009, 02:21 PM
ya youll get a better feel, but if they are bad enough to need replaced, they should rock around when the truck is on the ground.
  #14 (permalink)
Old 02-16-2009, 07:14 PM
bad_blue_oval bad_blue_oval is offline
ASE Master Tech
I also had a rubbing sound in my column before i replaced the gearbox. about 800 miles and havent heard it so far. You might actually have a couple issues going on. But it sure does sound like my problem.
  #15 (permalink)
Old 02-17-2009, 09:21 AM
n20 n20 is offline
So I jacked the front tires of the ground and on the drivers side , when grabbing the tire at the 10 &2 positions and shaking the tire moved quite a bit with some clunking noise. Also put a pry bar under the tire and lifted up and got some play and clunking. Did the same to the passenger tire and everything was tight, no play or clunking.
So this sounds like bad ball joints and a wheel bearing on the drivers side right? If so would i need to replace the passenger side bearing an b-joints as well? I hoped that this wasn't goin to be the issue. It sounds like a $$$ fix.
  #16 (permalink)
Old 02-17-2009, 07:59 PM
ASE Master Tech
may just be either ball joints or wheel bearing. Try having someone help you and watch the ball joint boots when they move the wheel. If your ball joints are loose, replace them first, then if you still have a problem replace the wheel bearing as necessary.
  #17 (permalink)
Old 02-17-2009, 08:29 PM
maddenjr maddenjr is offline
Send a message via AIM to maddenjr
ALL THESE TRUCKS NEED BALL JOINTS....MINE DROVE ME NUTS WIT A SHIMMY AND THE FINAL FIX WAS I PUT A SUPERLIFT DUAL STEERING STABILIZER IN IT..THAT WAS THE BEST THING I EVER DID.ITS BETTER NOW THEN THE DAY I GOT THE TRUCK NEW!!!IT A DREAM TO DRIVE NOW!!!
  #18 (permalink)
Old 02-18-2009, 06:21 AM
n20 n20 is offline
Well i looked at it a little better last night and had someone watch the ball joints and tie rod ends while i moved the tire and the balljoints didn't budge, but the tie rod ends were shot. They had alot of play in them. I think i'm going to fix that issue first and see if that cures it before jumping into b-joints. I'd hate to pay for ball joints if the fix was simply tie rod ends
  #19 (permalink)
Old 02-19-2009, 04:54 PM
ASE Master Tech
i bet that fixes it. same symptoms as a loose gearbox. If that doesnt fix it and you wanna jump into ball joints, prepare to replace all ball joints at once, and use high quality parts. let us know how it turns out
  #20 (permalink)
Old 02-20-2009, 06:40 AM
n20 n20 is offline
Well i'm gettin tie rods and a steering gear (its been shot since i got the truck, just haven't got motivated to fix it) hopefully this next week and we'll see if this cures it. I'll let you know
