weeping front diff at drivers knuckle - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Rammstein1224
post #1 of 9 Old 07-31-2014, 09:51 AM Thread Starter
1999 f350 4x4 dually 7.3lt. 316000km. At freeway speeds I can feel a slight knocking feeling thru the pedals. No steering wheel shudder and the wheels are normal temperature to the touch. Drives straight and true. Can also hear a slight rumble or wherring noise at times from the front end. I noticed some weeping from the front diff where it connects to the drivers front tire. It appears to be just before the universal joint/knuckle at the front drivers side assembly. It is definitely not brake fluid. I'm worried its bad news for the front diff ? I have not jacked up the truck to check wheel bearing stability yet. I expect the knocking and wherring noise is a wheel bearing but the weep from the drivers front knuckle is a bigger concern. I guess I might have to do both front inner seals and wheel bearings and.......... What am I in for??
MeTruck is offline
post #2 of 9 Old 07-31-2014, 10:17 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
As for the noise that can be anything in the front, but as for the fluid your axle seals are toast, it requires taking off the knuckles and pulling the axle shaft out and replacing that seal. Honestly if your doing that you may as well replace all the normal wears (ball joints, diff fluid, grease/replace the spindle bearing etc.)
Heavy_GD likes this.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
The Following 2 Users Say Thank You to Rammstein1224 For This Useful Post:
Heavy_GD (07-31-2014), MeTruck (07-31-2014)
post #3 of 9 Old 07-31-2014, 11:24 AM Thread Starter
That's what I thought too. Each hub assembly is 650.00. All the associated front end hardware will cost cost cost. Then there is labor. I'm starting to weep too.
MeTruck is offline
post #4 of 9 Old 07-31-2014, 01:43 PM
Chapter Director
Quoted: 5 Post(s)
Well you don't have to replace the hub assembly if its not bad theres a bearing on the backside that according to ford is unserviceable but yet somehow miraculously is serviceable and is only like 5 bucks
Search guzzle diesel and you will find the step by step on how to get to that bearing
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 9 Old 07-31-2014, 01:49 PM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
Where are you finding your price? I just searched and found them for 195 each. They are the timken brand which is the same as oem.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
MeTruck (08-01-2014)
post #6 of 9 Old 08-01-2014, 09:18 AM Thread Starter
From Lordco for 1250.00 each but with my contact there they are 650.00 each. They are ABS 4x4 hubs and bearings. The inner seals are $50.00 each. Cant imagine the ball joint costs. Also reaching my hand in further to the hubs they are very hot. Nonetheless the inner seals must be done so I might as well do what I can to rebuild the front end. I'll be taking the bus for a while.
MeTruck is offline
post #7 of 9 Old 08-01-2014, 09:42 AM
Chapter Director
Quoted: 5 Post(s)
Dude your getting jacked hard, ill bet if you found the right shop you could get your whole front end completely rebuilt tire to tire for around 2k including labor
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 9 Old 08-01-2014, 10:04 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
Parts list.
Ball joints $300
Seals (inner, outer, and knuckle) $250
U joints $30
Wheel bearings $750
Fluid $30
Torque wrench $100
Total $1500.
That's doing all the work your self. And if you do a little searching you could cut a few hundred bucks.
01 f-250, Standard
sbluke55 is offline
post #9 of 9 Old 08-01-2014, 10:13 AM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
You could just find the bad wheel bearing and change it now and keep an eye on the fluid tell you have all the parts.
01 f-250, Standard
sbluke55 is offline
