front axle leak - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-29-2014, 05:42 AM Thread Starter
front axle leak
hi to all
i have a 02 ford excursion diesel 4wd. i have notice that the front axle was leaking at the seal. i looked and the outer seal is loose.
what I'm looking to find out is there something else i have to change besides that outer seal at the knuckle.
if possible could you give me part numbers
thanks for your time
glen
Rittaskforce is offline
post #2 of 5 Old 07-29-2014, 07:40 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Well, the Bad News is,,,, there Is No "Outer Seal"
Fluid retention is done at the center section. What you see is called a Dust Seal and barely does it's job. They All look like that.
Changing the oil seal in the Ft diff can be a project, and depending on how much fluid you're losing, I'd consider just topping-off a couple of times a year maybe.
NoRalPh is offline
post #3 of 5 Old 07-30-2014, 05:51 AM Thread Starter
That sucks
Does the seal need to be pressed in I would like it seated back in the knuckle to hopefully slow air stop the leak
post #4 of 5 Old 07-30-2014, 06:18 AM
Quoted: 176 Post(s)
No, no, no,,, I'm tellin' ya, you're wasting your time......
The Dust shield isn't going to hold-back ANYTHING. It isn't meant to, and there's a huge gap between it and the axle (not to mention you have to buy a $60 Knuckle Seal to get to it).
You have 2 choices;
Keep an eye on the fluid level and maintain it.
-OR-
Replace the Inner Seals (This requires pulling the axles, pulling the carrier out of the diff, installing new seals in there, and you'll be buying 2 Knuckle Seals - Dust Seals - and you might as well put new U-Joints while you have them in your hand, they're actually cheaper than the Knuckle Seals)
NoRalPh is offline
post #5 of 5 Old 07-30-2014, 07:43 AM Thread Starter
See your point
