Wheel bearing grease - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2014, 06:01 AM Thread Starter
chpprguy's Avatar
I noticed Riff Raff sells an ABS greasable block off fitting,
Has anyone used this?
I don't believe I have any wheel bearing issues, but that's the point, I don't want to have wheel bearing issues.
If anyone has used it, your thoughts/tips,etc would be appreciated
chpprguy is offline
post #2 of 7 Old 07-10-2014, 02:39 PM
heykw's Avatar
I just saw this today on riffraffs sight.
I was also looking for a review on it.
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 7 Old 07-10-2014, 02:51 PM
ZMANN's Avatar
Quoted: 1776 Post(s)
link ?
I lube my unit bearings (06) you would be disappointed to see how much grease you can get in there at least 8 pumps with a large gun
i just use the rubber gun tip u can buy anywhere to fill the ABS port
i do mine when i have them off or at least the hubs off so you can watch the grease
i used a non graphite grease to keep the ABS signal happy
http://www.harborfreight.com/14-oz-s...ase-40710.html
We Miss you Ronnie
ZMANN is offline
post #4 of 7 Old 07-10-2014, 03:20 PM Thread Starter
chpprguy's Avatar
Awesome,
Thank you.
Looks like a smart preventative maintenance.
Sent from AutoGuide.com App
L99 250 ext cab flat bed , six speed, 275K , Airraid intake , 160/30 sticks , WW2 , 4" back exhaust , EBPV delete , CCV , FRX , southbend clutch, 05 headlights.
Future.... Turbo mods....
chpprguy is offline
post #5 of 7 Old 07-10-2014, 03:41 PM
ZMANN's Avatar
i had about 80,000 one one when i did it since I had to replace a seal
i did not do the other side at the same time kind of to do a test but at 100,000 i had a seal on that side go out
so i filled it up when i was there i won't complain if they have any issues 104,000 miles
on large tires is OK by me I will replace with Timken when the day comes
We Miss you Ronnie
ZMANN is offline
post #6 of 7 Old 07-11-2014, 11:47 AM
heykw's Avatar
Front ABS Grease-able Block Off Fitting - Riffraff Diesel Performance
Originally Posted by ZMANN View Post
link ?
14 Oz Sta-Lube® Sta-Plex® Extreme Pressure Premium Red Grease
heykw is offline
post #7 of 7 Old 07-29-2014, 05:30 AM
Gunner
GunnerB's Avatar
I have one and use it, it's cheap and less of a mess for me. Though you can accomplish the same thing with different tip for the gun.
2003 F250 7.3L CC XLT SB
AIS Intake
4.5" ICON Lift
Pre-Pump/Coolant/Transmission Filter
PHP Hydra
6.0L Cooler
ISSPRO EGT/BOOST/TRANS
B&W Turnoverball
Firestone Airbags
Warn Premium Hubs
Cobra 29 LX BT
2002 EX LIMITED 7.3L
DS Trans Cooler
Bilsteins
GunnerB is offline
