Do 99E 4X4 Have Front Wheel Speed Sensors? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-28-2014, 07:23 AM Thread Starter
Quoted: 60 Post(s)
Had my truck about a year. Been lurking here from time to time. I haven't found this discussed. I don't know my date, but it has the small brakes. There are sensor connectors behind the wheel wells, but nothing plugged into them.There are no signs that the knuckles have been molested and sensors removed.
My questions are:
Is this normal for the 99E to have the wiring, but not the front sensors?
If no sensors, is it 4 wheel ABS, or rear antilock only?
Any threads for additional information?
Thanks!
DaveP. is offline
post #2 of 12 Old 06-28-2014, 12:18 PM
Quoted: 7 Post(s)
Mine does not have front ABS speed sensors, nor does it have a passenger side air bag. I really don't know at what point in the production run those two things were added to the Super Duty trucks, but for the front ABS my guess would be somewhere around April 99. That's when most of the other front end changes happened.
Pikachu is offline
The Following User Says Thank You to Pikachu For This Useful Post:
DaveP. (06-28-2014)
post #3 of 12 Old 06-28-2014, 03:47 PM Thread Starter
Quoted: 60 Post(s)
My engine date is Feb 08/1999.
I have passenger side airbag.
But definitely no sensors.
I'm more curious now as to how the anti lock functions. Must be rear-only. Can't be anything else without front sensors.
DaveP. is offline
post #4 of 12 Old 06-28-2014, 04:02 PM
Quoted: 7 Post(s)
I think I read your post wrong, do you have a 99E, as in Econoline, or an E99, as in Early 99 Super Duty?
Pikachu is offline
post #5 of 12 Old 07-01-2014, 03:41 PM
Solid98's Avatar
Quoted: 9 Post(s)
Not all trucks had 4 wheel anti lock brakes but might have the wiring. My late 99 has rear wheel antilock brakes, but I also have wiring connectors between the front wheel liner and body for the lighted step bars. Kinda weird.
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #6 of 12 Old 07-01-2014, 04:17 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Not all 7.3s had 4wheel abs. after 99 though IIRC they all had the wiring
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 07-01-2014, 04:48 PM
Quoted: 7 Post(s)
Have you verified those connectors are for courtesy lights? I have them as well, and always assumed they were for ABS, since they're in the same place as they are on trucks with front ABS. I'll have to get under there with a multimeter one of these days I guess.
Pikachu is offline
post #8 of 12 Old 07-01-2014, 05:47 PM
Solid98's Avatar
Quoted: 9 Post(s)
Yes, they have power when the doors are open. They extend from the rear of the inner wheel liners to the rocker panels.
Solid98 is offline
The Following User Says Thank You to Solid98 For This Useful Post:
Pikachu (07-01-2014)
post #9 of 12 Old 07-01-2014, 06:22 PM
Quoted: 7 Post(s)
That's good to know. Thanks for that info!
Pikachu is offline
post #10 of 12 Old 07-02-2014, 10:30 AM Thread Starter
Quoted: 60 Post(s)
The wires on my truck aren't for courtesy lighting. They are different colors than the courtesy light circuit, and are different colors on each side. Yellow on passenger side, tan on driver side. I would expect sensors to be different color wires side to side, courtesy lights, no. Courtesy light circuit is blu/blk, the other wire would be ground. (Ford ctsy lights are 'backwards' from pretty much every other manufacturer on earth. Ford switches the B+, everyone else switches the ground side).
My 99 Super Duty has factory running boards. But they don't have the lights I've seen on Expeditions and Excursions. I've never noticed that Super Dutys have the lights. I'll start looking for them. If they don't have the lights in 99, then why would they have connectors for them?
But the connectors on my Feb 99 Super Duty are not for lighting. No way. Not the right colors, and different colors on each side. Someday I'll put my signal tracer on them, and see where the other ends are.
I'd triple check what they are for before plugging lights into them. I'm pretty sure solid98 is not correct about their intended function.
DaveP. is offline
