Carrier bearing replacement help needed - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-18-2014, 04:40 PM Thread Starter
I have a 2001 and my driveshaft has the slip coupling as opposed to the more common fixed coupling that uses the nut and flange. Plenty of info for removing the type with the nut but how is the bearing removed for the slip type coupling. I presume it presses over the spline but there is a shoulder between the end of the spline and bearing. See attached pic. Is the shoulder pressed on? Thanks.
2001 F350 CC SWB 6spd......currently getting a complete makeover.
LOOSEWHEEL is offline
post #2 of 2 Old 06-19-2014, 06:41 AM Thread Starter
Never mind. It's a pressed on flange. I realized it when i got the new bearing and it came with it.
