help! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-06-2014, 07:10 AM Thread Starter
help!
01 ford F350 crew cab 4x4. I have have a vibration in my truck since I bought it 1.1/2 years ago and I still can not find it. It starts around 30mph and continues up to 60, some days you feel it in the seat/ your butt. Other days its in the steering wheel. I had my rear drive line rebuilt last year, new slip yoke and u joints and balanced. Still have a vibration. Last month I installed new ring and pinion and bearings in the rear end and still have a vibration. I checked the front hubs and they feel good.
Where do I go from here? Maybe the machine shop hear in kalispell MT did not balance the drive line good enough? Another question is what is a good way to check the spring bushings?
Mtn.Tamer is offline
post #2 of 13 Old 06-06-2014, 07:14 AM
ThreeFitty's Avatar
Your tires balanced? My fathers GMC felt the same way when all the wheel weights came off for some reason. I'd start there
e99 F350 SRW 4x4 RCLB 7.3 Diesel (3/98)
-5" Diamond Eye Exhaust, straight piped
-RiffRaff 6637
-Sinister Diesel Coolant Filtration
-Hopefully a tune soon
ThreeFitty is offline
post #3 of 13 Old 06-06-2014, 10:19 PM Thread Starter
I have had them balanced twice with no change
post #4 of 13 Old 06-07-2014, 12:13 AM
Rodslinger's B1TCH
try mounting a gopro under the truck to point at the rear driveshaft while driving. you'll see it if it's out of balance that bad.
sometimes a slight engine miss can be mistaken for driveline vibration too. you'll feel it more in lower rpm's and will smooth out with higher rpm.
it could also be as simple as a bad shock. does it have stock tires and suspension on it? it could be a rear pinion angle issue which will cause the driveshaft to beat itself up.
steve604 is offline
post #5 of 13 Old 06-07-2014, 07:34 AM Thread Starter
Stock suspension, shocks are older, if I cost down a hill it still vibrates so I dont think its a engine miss. I will put a dial indicator on the dive shaft today. I do have alot of rear axle roll, so much that it makes a thump or thud every time I stop, and again when I take off. I just found where this was comming from last night, I think my u bolts are loose so I will try to tighten them today
post #6 of 13 Old 06-09-2014, 09:51 AM
blue99stroker's Avatar
Quoted: 247 Post(s)
cheap tires will cause what you are feeling because they cant balance them.
i have friend with a toyota t100 and the tires he got from les schwaub will not balance. and the ......... told him to get used to it we cant/wont fix it. one reason i will never go to les schwaub again.
the morons stacked about 4-5 weights on the rim to try and balance them.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #7 of 13 Old 06-09-2014, 10:14 AM Thread Starter
tires
These are BFG A/T TKO tires. one thing I found is the vibration almost goes away with a little weight on. could I take the tires and after market rims off my dads 01 dodge and put them on my truck? will the fit for a short test drive?
post #8 of 13 Old 06-09-2014, 10:28 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Sorry won't fit. I had bfg's on my truck and had a horrible time with them. Ended up buying a new rim because the tire shop said it was bad. Turn out the tire was bad from the get go. I hate them and will never buy a set again.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #9 of 13 Old 06-09-2014, 01:36 PM
Rodslinger's B1TCH
All of this and you say that the vibration goes away with some weight in the back. This points to a suspension issue. Check for cracked/broken leaf springs and replace the shocks. Make sure everything else is tight.
steve604 is offline
post #10 of 13 Old 06-17-2014, 02:30 PM
Montstroke's Avatar
I have a slight vibe on mine to. All other components are good. Its not really too bad, I suspect the crappy BFG tires that came with the truck. I'll deal with it until I get my new Toyo's and see if it goes away. Or maybe U-Joint.
2001 F250 CCSB
Less than cold air intake
RR Billet Wheel
EBPV gone
AIH gone
Turbo back 4" MBRP muffled
6 PHP tunes
315's with Zone level kit
On board air
Suspension air bags
Montstroke is offline
