Bad front wheel bearing. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-03-2014, 08:01 AM Thread Starter
kblv247's Avatar
1999 f250 4x4, crewcab, manual hubs, 2-wheel ABS
manufacture date 1/99 (which i think means i have late 99' motor and tranny setup with early 99' running gear, right?)
So i noticed that my truck was pulling to the driverside when braking. so i jacked it up and the wheel has at least 1/2" play up/down and im sure its the wheel bearing assembly. im going to do the update to 2000 year wheel bearing assembly and rotor on this side but i also have a leeking pinion seal and i would also like to change the seal on the end of the axle tube on this side as well. Can some one list all the seals i should sevice while im in there. i thought about doing the u-joint as well. as for the pinion seal can i change this without removing the pinion and is there anything special about removal and install?
kblv247 is offline
post #2 of 4 Old 06-04-2014, 09:02 PM
heykw's Avatar
Check the other side. My money is on the break caliper float pins being seized up.
When you say "up and down" do you mean in and out?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
post #3 of 4 Old 06-16-2014, 11:50 AM Thread Starter
kblv247's Avatar
it was a bad wheel bearing. when jacked up i could rock the tire in and out by pushing and pulling on the top and bottom of the tire
kblv247 is offline
post #4 of 4 Old 07-02-2014, 11:07 AM
Isn't excessive wheel play indicative of bad ball joints? I could be wrong, just throwing it out there.
Jeremy Long
2000 7.3L F350 4x2
Oceanside, CA
Long5937 is offline
