Napa hub assembly junk? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-30-2014, 05:58 AM Thread Starter
tgarrisoniv's Avatar
99.5 PSD ex cab 4x4
replaced inner and outer axle seal on both sides and hub assembly with napa brand one about 7k miles ago. this morning driving to work hit a pothole in I-state and i can feel wobbling going on down there. does it again as im about to pull up to work so when i check it, theres a ton of play on the side with the newer napa hub assembly(passenger side). when i installed it, it seemed like it had a bit too much play but now its pretty damn loose and the seals dont look too good either. what is supposed to hold the axle from moving here? the locking hub? or more so the axle seals?? i have stock locking hubs but ive been thinking of upgrading soon. i really dont want to invest in some $270 new locking hubs with a loose fit and tear them apart. any input would be appreciated guys!
tgarrisoniv is offline
post #2 of 6 Old 05-30-2014, 06:01 AM Thread Starter
BTW truck is NOT on 40x22s anymore. its on 35x18s so no hub assem should wear that fast.
post #3 of 6 Old 05-30-2014, 06:15 AM
ZMANN's Avatar
Quoted: 1782 Post(s)
you lost me a little because you use the term HUB so many times
but I think yous asking about the "unit bearing" quality of a Napa unit ? and that being the first year for the unit bearing I believe ?
if so
NAPA sells more than one brand I think ? Timken is the OEM and many like to stay with those but 7k isn't very good even for a cheap china brand however I am not shocked
if you felt it being loose when new you should have returned it they should feel tight
any warranty recourse ?
the axle question
is the needle bearing holds the axle it is inside the unit bearing and replaceable by itself
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 05-30-2014, 06:39 AM Thread Starter
sorry about that. lets clarify:
locking hub- the outer manual locking gear that engaged axle shafts into lock or unlock position.
hub assembly- the assembly that the locking hub sits in that is the bearing used for rotation, bolted to the axle with 4 bolts.
yes it is still under warranty and i probably should have just went ahead and got a new one. im going to do that but i think it was so loose it has also ruined the seals (which i bought at the same time, they may still be under warranty too.)
i was wondering if the hub assembly is actually supposed to support the axle shaft. or is that the job of the seals mainly? ive done this job a few times and while i like to save money, im more than willing to purchase a quality set of locking hubs. i dont want to purchase them and have them ruined by a bad assembly (unit bearing) though! ive heard many times of people purchasing them and then blowing them out constantly... what is the issue there?
post #5 of 6 Old 05-30-2014, 07:15 AM
ZMANN's Avatar
while it's not unheard if to refer to the unit bearing as a " hub"
lets just call it a unit bearing moving forward and save the term Hub for the locking hub
the axle does not count on the seals to hold it in place
it is supported inside the dif / the u joints hold it and the inner needle bearing inside the unit bearing
you could remove the hub all together and drive with no issues
I know what the inner seal your referring to is but the outer I am not so sure ?
but i would return the unit bearing and see if they have brand options
if it's an ABS unit a lot of use pre lube them through the sensor port and get the needle bearing coated also
then get you new locking hubs , playing it safe, I agree with that even though wiping out a locking hub with a bad unit bearing isn't common
We Miss you Ronnie
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
tgarrisoniv (06-02-2014)
post #6 of 6 Old 05-30-2014, 10:39 AM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
Huh huh...you said "unit"
Corey@CNCFAB is offline
