transmission temps - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-16-2014, 02:49 PM Thread Starter
transmission temps
Hello everyone its been a long time since ive been on here and for that I apologize.
First off I need to update my sig bit dont really have time right now. New mods on the truck are lift kit running 38 inch toyos.
My problem is running around town empty with no load and not hot rodding around my trans temps are running around 180 degrees I know that is way to hot with the outside temp being 82 degrees.
I know I need to do a mod of some sort for my trans cooler but even without that I don't think I should be running that hot. I did notice a little bit of leaking tranny fluid from around the inspection plate. Is there a way to check and see if the current cooler lines are plugged and the fluid going thru the bypass? Or do you have any other ideas?
Thanks in advance.
2000 f-250
short box extended cab
4 inch exhaust
K&N intake
TS performance chip
8 inch rough country lift
38 toyo mud terrains
DIY boost fooler
glow shift A pillar gauges(poke fun I dont care they have treated me well so far)
Latest rig 2009 cc lb
s&b intake
dpf/cat delete
spartan tuned
the2ndtinman is offline
post #2 of 2 Old 06-09-2014, 08:58 PM
Jerrybizzle's Avatar
Quoted: 25 Post(s)
Tru cool transmission cooler or 6.0 cooler would be good for you.
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
