Dana 80 pinion nut binding - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-01-2014, 05:28 PM Thread Starter
recordbreaker5's Avatar
I was changing the pinion seal this afternoon. Everything came off just fine. Installed new seal, reinstalled the yoke, washer, and pinion nut. Made sure my marks were lined up correctly and began to torque down the nut. It goes to about 5 threads deep and the whole drivetrain wants to bind. The truck is up on a drive on lift, parking brake engaged. What am I doing wrong? I really need to figure this out by tomorrow, supposed to be going out of town over the weekend.
2001 F350 CCLB DRW- Edge Insight CTS, PHP Hydra, 4" MBRP turbo back, AFE Stg 2 XP, Mag-hytech trans pan, Garret Non-EBPV pedestal, Garret Non-EBPV exhaust flange, DS wastegate controller, DS HPOP adapter plate, DS thermostat housing w/ 203*, DS coolant filtration system, DS transmission filtration system, Max-AC assist valve, Tru-cool transmission cooler, DS SS ESOF lines, Bilstein 5100 shocks, Bilstein 5100 steering stabilizer
recordbreaker5 is offline
post #2 of 2 Old 05-02-2014, 03:47 PM
rosshurlow1's Avatar
When I did mine I reused the old nut(they say you shouldn't but I did) 30k miles later no problem, if you have a new nut try the old clean the threads ,best done with wire wheel. You should use blue thread lock too
rosshurlow1 is offline
