Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
  #11 (permalink)
Old 03-16-2009, 07:41 AM
Nightcrawler Nightcrawler is offline
yea doing that right now. is there a clip in the diff holding the drive shaft or will it just pull out? waiting your reply before we go any further.
  #12 (permalink)
Old 03-16-2009, 07:49 AM
Fulltime Fulltime is offline
Once you take the 4x4 locking hub off there is a snap ring inside alongwith a few thrust washers. Take the snap ring off and remove the washers. Then remove the brake caliper and then remove the 4 nuts on the inside of the spindle that hold the wheel bearing hub on along with the ABS plug. The hub will pull out with a little effort then u can remove the axle. Once the axle is removed then you can remove the nuts to the ball joints and steering tie rod. Once the 2 ball joint nuts are removed you can then proceed to remove the spindle with a little effort the spindle should come out.
Good Luck
Mike
  #13 (permalink)
Old 03-16-2009, 08:13 AM
do i need to take the diff cover off? is there a clip inside the diff on the end of the drive shaft?
  #14 (permalink)
Old 03-16-2009, 08:45 AM
No need to take the differential cover off. The axle will pull out. There are no C Clips on the axles.
  #15 (permalink)
Old 03-19-2009, 07:11 PM
Jeeez that was a bit of a mission. I could not get on the pc in time so I took the diff cover off & like you say there was no clip. I thought It was better to check than keep pulling on the drive shaft. At least it was a chance to change the diff oil.
I could only do the passanger side ball joints as I wanted MOOG & the place I get my parts only had the one side in stock. He is getting me the others & brake pads & discs in the next day or so.
Here are some pictures.
The auto lock was a bit of a nightmare to get off.
This metal ring was a little tricky to get back in.
In a couple of months I'm going to spend a few days wire brushing everything including the chassis & underseal & clean,paint or grease everything. I was supprised how the winter has made everything look so bad.
  #16 (permalink)
Old 03-19-2009, 07:26 PM
Glad you were able to get the axle out. I should have told you that you can put a pry bar next to the u joint on the axle and pry it out alot easier than trying to pull it out. I learned this the hard way after thinking it would just pull out. I then used the bar and it really did pull out fairly easy with the bar verse trying to pull it. Good luck on the next one.
Mike
  #17 (permalink)
Old 09-11-2009, 07:40 AM
hntwhitetail hntwhitetail is offline
Mike
Nice write up guys
  #18 (permalink)
Old 09-13-2009, 07:31 AM
fleastang fleastang is offline
Are you guys having issues with your ball joints or replacing them as preventive maintenance when doing front hub bearing changes? I have a late '99 and have had no issues with the front end to date but am going to replace the hub assemblies as preventive maintenance. Also when changing hub assemblies, (as i am about to do), I am going to replace the yellow o-rings and at $10 set probably new hub bolts but do you recommend changing the front hub seals also? I don't have those yet and noticed some places put those in their hub replacement kits they sell. Looks like about $35 each. Thanks ......................and thanks for the write-ups!!
  #19 (permalink)
Old 09-22-2009, 11:23 AM
Nice Write-Up. How did you get the metal ring back in? Any close up shots of that?? What is the metal ring??
Thanks
  #20 (permalink)
Old 09-24-2009, 09:38 PM
strokethis04 strokethis04 is offline
did you guys change the axel seal in the diff tube when you did the ball joints? i gotta do dads one of these days so i was woundering what it was like?
