Brakes pulling to driver side - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-09-2014, 10:56 AM Thread Starter
Quoted: 16 Post(s)
Feedback Score: 3 reviews
My truck does great under normal braking but pulls hard to the driver side if I apply the brakes hard. I put new pads and rotors on about 3k ago. Any ideas?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #2 of 14 Old 04-09-2014, 11:45 AM
Harley516's Avatar
you possibly have a sticky caliper piston, this causes the brakes to drag and heat up which causes them to be grabby. Check the caliper over and make sure that the piston is moving both ways. You can pull the piston out and clean it up or just buy a new caliper if indeed this is the problem. Good luck .. please post what you find.
Harley516 is offline
post #3 of 14 Old 04-09-2014, 12:09 PM Thread Starter
Quoted: 16 Post(s)
Is there a write up on how to grease the slide pins?
post #4 of 14 Old 04-09-2014, 02:19 PM Thread Starter
Quoted: 16 Post(s)
One of my driver side pins is bent.
Thanks
post #5 of 14 Old 04-10-2014, 01:28 PM Thread Starter
Quoted: 16 Post(s)
And that wasn't it. I guess I will try bleeding both calipers
post #6 of 14 Old 04-10-2014, 04:25 PM Thread Starter
Quoted: 16 Post(s)
Bled both calipers and still the same. Caliper bad?
post #7 of 14 Old 04-10-2014, 05:09 PM
timmyboy76's Avatar
id be look'n at the p/s caliper and pins
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 14 Old 04-10-2014, 06:30 PM Thread Starter
Quoted: 16 Post(s)
Pins move free and caliper moves freely, what seems normal. Both sides bled good and neither had any air in them. Anything in particular to look at?
Somebody suggested the abs block might be going bad and not sending fluid to the pass. side. Never heard of that but sounds feasible. I found the block under the driver side battery but can't find a plug to undo?
post #9 of 14 Old 04-10-2014, 07:59 PM
This could be a number of things that I know of, just from personal experience. Try taking the driver side tire off. Grab the hub, and try to pull it in or out. Try to move it left to right, up and down. If there is any movement, replace it. That fixed the exact problem with me, on the passenger side.
Tommy7.3 is offline
post #10 of 14 Old 04-11-2014, 03:09 AM Thread Starter
Quoted: 16 Post(s)
I replaced driver side hub when I did the brakes 3 or 4 weeks ago. It had a lot of movement
