4R100/Autometer Transmission Temp Sender? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-08-2014, 04:31 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I got a new transmission in the fall, and my old sender does not work with the new stock pan. I have Autometer C2 gauges, and the old sender has 2 wires that come off of it. Autometer told me to use sender 2252, but couldn't verify that the probe on the sender would fit. Has anybody used the 2252 sender in the "test port" area of the 4R100 and can verify that it fits?
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 6 Old 04-29-2014, 12:04 PM
DieselManor's Avatar
Hi Bio,
It should fit just fine. It's 1/8"NPT. The only problem that you might have is the tip coming in contact inside the trans housing.
Here's the sender if you want a look. Auto Meter 2252 Replacement Temperature Sender at DieselManor
In order to give you the extra length we sell an adapter called a Sender Extender here: Specialty Fittings at DieselManor
You simply install the sender extender into the port and then the sender into the sender extender.
Hope that helps.
David Murphy
DieselManor is offline
post #3 of 6 Old 05-04-2014, 08:51 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Got it installed today. Threads right in without an adaptor for anybody needing to know in the future!
post #4 of 6 Old 05-05-2014, 07:22 AM
Good deal. Glad it all worked out for you.
David Murphy
post #5 of 6 Old 05-05-2014, 07:27 AM
ZMANN's Avatar
Quoted: 1357 Post(s)
I didn't know you guys were a supporting vendor
glad to see you!! I always link to your awesome install sheets when trying answer a question on the forums !!
We Miss you Ronnie
ZMANN is online now
post #6 of 6 Old 05-05-2014, 07:36 AM
we've been one for several years now. Just haven't been doing that much posting on the forums.
David Murphy
