Differential clutch pack replacement - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-30-2008, 05:51 PM Thread Starter
Question Differential clutch pack replacement
I am going to replace my clutch packs in my 2003 F350 7.3L SRW 4x4. (dana 80????). The only tricky part about it after reading about it is the BACK LASH on the gears. It looks like they have you look at it before and and after. It looks like it is pull out fix and put in. Is it simple or does this need a diff specialist?
I attached a DRW procedure, any one have anything better?
P.S. LOVE THIS PLACE
GETPHILTAFISH TOW TRUCK is offline
post #2 of 6 Old 11-30-2008, 05:55 PM
Broncoguy's Avatar
Dana 80
I am no differential expert, but I would think that as long as you did not mess with the pinion depth or carrier bearing shims, it shouldn't change the backlash at all.
1999.5 F350
4" Straight Pipe / Gauges (Pyro, Boost)
Wicked Wheel / Wg delete / Boost fooler
Tymar intake / Zoodad Mod / NChornet CCV mod
Hpx Crossover / Fuel CCK / ITP prepump tank mod
FPR Shim w/ underhood gauge
AIH Delete / Non Ebpv pedestal w/ valve delete
TW 6 position chip (will never own another canned toon)
3.73's / 6 speed manual 4x4
Still messin with it
Broncoguy is offline
post #3 of 6 Old 12-06-2008, 05:53 PM
Fulltime's Avatar
I rebuilt mine the other day and it was pretty straight forward. I took out the old clutch packs and shims and measured the shims and replaced with the same thickness. I all bolted together fairly easy. I also changed ghe gear rato from a 373 to a 430.
Good Luck!
Fulltime is offline
post #4 of 6 Old 12-06-2008, 06:07 PM Thread Starter
Where did you get the clutch parts?
2003 F-350
7.3L Stock Turbo
AFE Stage II Dry
FS-2500
High pressure oil, head cross connect hose
Boost gage
Auto Trans
SRW
Crew cab
4X4
135K
post #5 of 6 Old 12-06-2008, 06:11 PM
Fulltime's Avatar
I got them thru justdifferentials.com and they must have got them from the ford dealer as they came in a ford dealer box.
Fulltime is offline
post #6 of 6 Old 12-06-2008, 06:16 PM Thread Starter
Thanks Fulltime. I hope to tackle it over the holidays. I'll post how it goes.
2003 F-350
7.3L Stock Turbo
AFE Stage II Dry
FS-2500
Boost gage
Auto Trans
SRW
Crew cab
4X4
135K
