Unusual 4x4 Sound - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-19-2014, 09:08 PM Thread Starter
Firewood Hack
Locust Cutter's Avatar
Send a message via MSN to Locust Cutter
Unusual 4x4 Sound
I have read the threads and may already know the answer, but I'm asking anyway... The '02 PSD in my sig has been making an unusual noise lately when the four-wheel-drive is engaged and the hubs are locked - similar to a hay elevator or an old combine for the farmers on here. Basically it sounds like a dry chain running loosely and/or binding on a sprocket.
In 2-wheel there is no noise whatsoever. I will be servicing my needle bearings soon as preventative maintenance, but i'm wondering if the transfer case could be low on fluid... Either way, once I get my truck back from the shop for an on/off MAP sensor issue, I will be servicing all drive-line fluids anyway but I am curious if this could be indicative of a pending t-case failure. I truly hope not as after spending $3500 on sticks, intake, switch, gauges, WW2 and some other odds and ends, the wife would NOT be impressed if it now needed a t-case.
As a disclaimer, I bought the truck about 3 months ago used and the previous owner did some maintenance, but seemingly only when he couldn't put it off any longer. I bought it knowing it needed work, as the price was at a point I couldn't turn down for a running/driving 4x4 CCB/flatbed dually 7.3/ZF-6dp combo....
Any thoughts?
Bryan TAPS Member
TSgt KSANG
Computer guy now, but former B-1b and '135 Crew Chief
"IYAMYAS" -"Kicked the tires and lit the fires!!!"
'03 F-250 6.0/5R110 4x4 RC/LB, 4" diamond eye exh, SCT X4, EGR missing, ARP studs, new oil cooler... (joint venture between Dad and I)
'02 F-350 CC/LB Flatbed Dually 4x4, 7.3PSD/ZF-6 -WW2, gutted factory exhaust, F.F. Stage 1's, 6637 filter, TS6 w/tunes by Matt and gauges.
'01 f-350 gasser/hand shaker 2wd - Burned to the ground
Locust Cutter is offline
post #2 of 3 Old 03-23-2014, 06:30 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
the transfer case only holds 2 quarts of atf.
takes 5 minutes to drain it and refill it. so that would be a place to start.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 3 Old 03-27-2014, 09:11 PM
heykw's Avatar
I bet the t case is dry
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
