Hard pedal, spongey brakes? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-04-2014, 04:32 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Feedback Score: 3 reviews
Hey all.
My 99 is having some weird brake issues.
When driving, to stop, I have to apply pressure to the brakes, then back off and go again before they come on. I have replaced the pedal switch but its still there. It takes a second or two before it seems to realize im push the pedal. If you just jam it, its really hard but the brakes are really soft.
Any ideas?
~ The Maddawg
2005 F250 6.0 Powerhouse Lariat
Bully GT Platinum with Quick Tricks
Bully Dog intake
Everything else stock.
Moto Metal 18in rims wrapped in 275/70 Mud Claw Extremes
2003 F250 cclb flat bed.
All stock 7.3 turtle
maddawg89 is online now
post #2 of 9 Old 03-04-2014, 04:45 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 331 Post(s)
Booster? If you mash the pedal in park do you hear the booster working? Is your hydroboost original?
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 9 Old 03-04-2014, 04:47 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Both very good questions. I'll check when I go out. I dont think it does. And I got the truck 2 years ago so I'm not sure if it's original.
~ The Maddawg
Bully Dog intake
post #4 of 9 Old 03-04-2014, 08:07 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
There is a bit of PS pump whine when I put my foot on it in Park
~ The Maddawg
Bully Dog intake
post #5 of 9 Old 03-04-2014, 08:37 AM
LoxDiesel's Avatar
Quoted: 331 Post(s)
Do you lose steering when brake pedal is pressed?
@loxdce
post #6 of 9 Old 03-04-2014, 08:41 AM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
It could be a couple of things. Sticking caliper or air in the system. I would bleed your brakes first before buying parts. Start at the passenger rear then driver rear. Followed by the front passenger and then the frond drivers. Pump the brakes with the key off tell firm and hold. Have someone crack the bleed screw and wait tell the fluid stops and shut the bleed screw. Then pump again. Do not lift your foot while the bleed screw is open or you will get more air in the system. Also make sure you keep the master cylinder full. Also BRAKE FLUID EATS YOUR PAINT. Clean any fluid that gets on your paint. To help keep the mess down find a hose that will go over the bleed screw and route it to a bottle. Since your truck is over 10 years old I would flush your brake system. You just bleed each one tell you get clean fluid.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
maddawg89 (03-05-2014)
post #7 of 9 Old 03-04-2014, 02:38 PM
remove the calipers and clean and grease the slider pins.
03 F250 XLT
5.4
182,000 and still goin strong
busa dave is offline
post #8 of 9 Old 03-05-2014, 09:32 PM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Thanks guys!
I don't lose power steering, but I have noticed lately, the truck will NOT creep in drive like it used to. Like the brakes are on. I alsoe noticed, when idling in a parking lot, making a turn, the brakes grab. the truck almost stop if I don't give it gas!
I have bled the system but not to the extend mentioned above. I will try that when I get some help on it. Also, I probably need to do slide pins again..... It sat in the yard from thanksgiving till beginning of February till I could get the tranny rebuilt so theres no telling what bugs got in it.....
Bully Dog intake
post #9 of 9 Old 03-09-2014, 07:21 AM Thread Starter
The Maddawg
maddawg89's Avatar
Quoted: 280 Post(s)
Greased my slide pins and it seems to be better but I still need to bleed the system...
~ The Maddawg
Bully Dog intake
