Front end clunk? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-19-2014, 04:18 PM Thread Starter
dajain's Avatar
Cool Front end clunk?
Hey guys, She's a 2000 F250 4x2 and having some noise issues in the front end. So, here is a short version. She has almost 250K miles on her.
Bought the truck, the alignment was far enough out to blow the front 2 tires and damage fenders, inner wells, etc.
After that happened, decided to replace all steering parts from the gear box to the knuckles, replace ball joints, and replace the wheel bearings and races. Yes, front end rebuild.
Had it aligned and she runs straight now, but I am still getting a clunk out of the front end when I hit bumps or pot holes at lower speeds. 50 mph or less.
It is a heavier clunk and not a body panel noise. What else could it be? Would old shocks be make a heavy noise? Maybe the bushing at the end of the suspension arm?
Any info would be great on this one.
2000 F250 PSD 4x2 SWLB
Bone stock until:
PHP 6 position switch
Gauges (pyro & Boost)
Muffler delete pipe
6637 intake
Nothing more planned except pulling my toys.
95% of Harleys are still on the road...
The other 5% made it home.
dajain is offline
post #2 of 7 Old 02-19-2014, 04:44 PM
Quoted: 132 Post(s)
Feedback Score: 3 reviews
In most cases, it's the swaybar mounts/links that do that, have you looked at them closely?
NoRalPh is offline
post #3 of 7 Old 02-19-2014, 04:52 PM Thread Starter
dajain's Avatar
Didn't think about the sway bar. It makes sense. I was just thinking moving parts.
I'll check it tomorrow and go from there.
Thanks for the re-direction!
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #4 of 7 Old 02-19-2014, 05:55 PM
scagle1's Avatar
Also seen it when the spring eye bushings get wallered out of round
Sold 01 350 6" on 37's and mild mods, 00 X 4" on 35's, 02 f350 4" 35's modded from fan to drive shaft, ridin the 03 with nose conversion with 125k and counting upwards slowly.
Never had CNC's poo on any of it, never will.
scagle1 is offline
post #5 of 7 Old 02-19-2014, 09:31 PM
Macon's Avatar
I had that clunk and it was the sway bar. I jacked up the frame until the suspension was zero pressure. Started yanking and pulling on things. Sway bar was loose. Tightened it up, no problem.
And x2 on checking the bushings. friggen bushings.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #6 of 7 Old 02-20-2014, 05:55 AM Thread Starter
dajain's Avatar
I'll look at both things today. They both make sense. The sway bar makes the most sense so I'll start there.
Thanks for the input guys!
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
post #7 of 7 Old 02-20-2014, 11:41 AM Thread Starter
dajain's Avatar
Went and installed new sway bar links. Old ones were worn pretty good but while I was under there and tightening the new parts I was also looking around.
What I seen is my drivers side radius arm bushing is completely shot. Of course, no one has them in town so I'll have to order some.
Bone stock until:
Muffler delete pipe
6637 intake
dajain is offline
