Thinking hub is bad - Ford Powerstroke Diesel Forum
post #1 of 4 Old 02-19-2014, 04:12 AM Thread Starter
Thinking hub is bad
2003 4x4 7.3. dwd, cc has 85k. I just bought the truck a couple months ago. Had pulsation in the brake pedal and vibration in the steering so I decided to replace all rotors and calipers. Dial indicator shows over .010 run out on front passenger side with old and new rotor. Does this mean I have a hub with worn bearings?
thanks in advance
ml0923 is offline
post #2 of 4 Old 02-20-2014, 06:38 PM Thread Starter
Update...The po had smacked the outer edge of the hub with a hammer and dented or pushed in the edge to the point where the rotor would not sit flush to the hub. I filed down the bump and now run out is within spec.
ml0923 is offline
post #3 of 4 Old 02-21-2014, 07:07 AM
RPM Tim's Avatar
Thanks for the update. Did these things fix your p brake pulsing? Was the vibration only while braking?
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #4 of 4 Old 02-21-2014, 04:18 PM Thread Starter
I have not drove it yet, plan on finishing this week end. I will post my results. Im thinking it has to be most if not all the problem. U joints, ball joints, bushings etc are all still tight. I also replaced the shocks and had the front tires taken off rims and switch with two of the best rears. The po never rotated the tires and the fronts were cupped really bad.
ml0923 is offline
