4wd stopped working in snow storm NEED HELP - Ford Powerstroke Diesel Forum
post #1 of 3 Old 02-18-2014, 06:04 AM Thread Starter
2001 F350. The past few days my 4wd has been acting up. Yesterday I parked facing a snowbank at the end of my driveway, and the vacuum seal on the auto hub stopped engaging (it has the 4wd dial on the dash). So i locked the hubs and put it in 4wd and tried to back out of the drivewag and still nothing, just rear tires spinning. Since i parked right in front of a snow bank and had no room to go forward, i figured maybe i just needed to roll the truck forward for the hubs to lock in place and it would work. So i had my buddy pull me out of the spot where i was stuck and tested out the truck. I just drove it up the hill on my street with a little under an inch of snow on the ground and it was going good for a few seconds then all of a sudden I heard a loud sound from the front end that sounded like something cracked or snapped and i started swerving and sliding on the road and almost got stuck on the hill, which I'm assuming is a sign that 4wd went. That being said, I've heard the cracking/snapping sound in the front end a couple times in the past few weeks but 4wd still worked. And also the passenger side hub is a real ***** to lock and unlock, and you can even wiggle the hub itself a little. So my question is: do I need new locking hubs? And if not what else could the problem be?
Mzarlenga is offline
post #2 of 3 Old 02-18-2014, 06:10 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
if your dash light is showing 4x4 you likely are ok transfer case wise
it does sound locking hub related but it's easy to pull and inspect
We Miss you Ronnie
ZMANN is offline
post #3 of 3 Old 02-18-2014, 07:13 AM Thread Starter
What should i look for when inspecting?
