need help with 4x4 please - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 12 Old 02-15-2014, 03:23 PM Thread Starter
Colin7.3's Avatar
hey guys i have an issue.
my 4x4 wont engage.
new shift motor, new relays, and new switch on dash.
lights come on when starting truck.
i have manual front hubs so i know thats not the issue.
i checked the fuses they are good atleast the ones thats say deal with the ESOF in the owners manual
i can use a jumper wire and jump the relay in the box under the hood and the transfer case will shift and the llights will indicate what range it is in on the dash.
any ideas?
thanks in advance
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #2 of 12 Old 02-15-2014, 03:39 PM
john galt's Avatar
Quoted: 1227 Post(s)
sounds like the relay? I would think, but mine is having a similar problem so...
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #3 of 12 Old 02-15-2014, 03:54 PM Thread Starter
Colin7.3's Avatar
but both relays are new....
Colin7.3 is offline
post #4 of 12 Old 02-15-2014, 04:31 PM
Gene's Avatar
Quoted: 3 Post(s)
Had the same problem on mine a few years ago. Just needed to clean the electrical connector and add in some di-electric grease to the plug, and haven't had an issue since.
john galt likes this.
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #5 of 12 Old 02-15-2014, 04:48 PM Thread Starter
Colin7.3's Avatar
which plug?
Colin7.3 is offline
post #6 of 12 Old 02-15-2014, 09:44 PM
the t-case shift module is behind the glove box, top right side. Check for chafed/ loose wires/ plugs. then check for voltage at the plug. I cant remember what pin it is but i think it is yellow with orange stripe, but not posative on that part.
yooper906 is offline
post #7 of 12 Old 02-16-2014, 03:43 AM Thread Starter
Colin7.3's Avatar
Thank you. I'll check it out
Colin7.3 is offline
post #8 of 12 Old 02-16-2014, 05:21 AM
delta99's Avatar
4X4 NOT ENGAGING
One of you other posts has some answers
Colin7.3, john galt and Heavy_GD like this.
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #9 of 12 Old 02-17-2014, 06:49 PM
Gene's Avatar
Quoted: 3 Post(s)
Originally Posted by Colin7.3 View Post
which plug?
There are two under the truck on the transfer case. The one forward on the drivers side was the one I needed. It wasn't making a good enough connection.
Gene
Gene is offline
post #10 of 12 Old 01-04-2015, 10:27 AM
Stroker7.3's Avatar
How do you use a jumper wire to engage the 4x4?
2000 FORD F250 SUPERDUTY
Stroker7.3 is offline
