front axle bearing gone? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-07-2014, 06:38 AM Thread Starter
i have a 02 excursion 4wd with the 7.3L. i have been chasing this consistant vibrating/grumbling noise for a few weeks now. i have replaced both front hub assemblies, new rims and tires, alignment, shocks, bushings, front and rear drive shaft u joints. i was about to replace the front axle u joints when i noticed the drivers side axle as it comes out of the axle tube has ALOT of play in it. what i have been reading is i need to replace the inner axle shaft, seal and bearing but when i called ford they only sell the whole unit. also from what i have read the axle seal is pressed on to the shaft itself and requires a dealer to install. anyone have a sticky somewhere i can see or know where to get a good priced shaft from?
greasemykey is offline
post #2 of 5 Old 02-07-2014, 04:28 PM
mdwaterfowler's Avatar
I have been chasing a similar whine from my front end. I never considered a front axle bearing. The noise coming from my rig comes on around 45 mph and continues in till I get above 55mph. No change while turning or under acceleration or deceleration. Sorry I got no info on how to change the bearing out, but curious so see if this solves your problem. Any feed back about any similarities in your issue and mine would be appreciated. Thanks
2001 7.3 excab long bed 145,XXX
Gauges boost, pyro, trans, fuel
4" diamond eye turbo back
Donaldson air filter
Wish List-
new trans
TS Chip
mdwaterfowler is offline
post #3 of 5 Old 02-07-2014, 04:41 PM Thread Starter
it also makes a crunch sound when the truck is turning hard left. only why the weight is shifted off the left front tire.
The Following User Says Thank You to greasemykey For This Useful Post:
mdwaterfowler (02-07-2014)
post #4 of 5 Old 02-07-2014, 04:44 PM
Sounds like I will keep searching for my issue. Best of luck with your repairs. Thanks for the quick reply.
Wish List-
new trans
TS Chip
post #5 of 5 Old 02-17-2014, 12:35 PM
whitextreme's Avatar
I just had a front wheel bearing go bad and it got so hot that it siezed the caliper on that side. My grumble was my brakes dragging. Just something to check out
whitextreme is offline
