Front Axle play/Transfer Case - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-22-2014, 05:12 PM Thread Starter
I have had some clunking/binding going on for a while and I'm set up to do needle bearing service/front u joints & seals as there is play on the spindle as it comes through the hub. While i'm at it we are going to do the front drive shaft u joints and there is a little bit of slop, maybe that is my noise issue?
My question is this-when you rotate the front drive shaft, i can see both sides turning at the u joint. But i grabbed the drivers side joint and i could keep it from moving while still turning the xfer drive shaft.
Is this normal? I've never payed any attention to that, and now i'm worried that it could be an issue in the differential.
HELP PLEASE!!
mkfan17 is offline
post #2 of 5 Old 01-22-2014, 05:15 PM
jse51599's Avatar
Just a thought, maybe it's because it's an open differential.... (if the differential is stock) Were the outer hubs locked?
6637, Diamond Eye Turbo Back, Riffraff Billet Intake Plenums and Intercooler Boots, WW2, Deleted EBPV
305 70 16 Toyo A/T IIs
Jim
jse51599 is offline
post #3 of 5 Old 01-22-2014, 05:32 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 403 Post(s)
Totally normal front ends don't have posi traction or limited slip. Clunking may be the needle bearings in the hubs gone which lets the 4x4 shaft bounce around in there.
@loxdce
LoxDiesel is online now
The Following User Says Thank You to LoxDiesel For This Useful Post:
mkfan17 (01-23-2014)
post #4 of 5 Old 01-22-2014, 07:52 PM Thread Starter
Yea it's all stock front end. Hubs were unlocked too.
mkfan17 is offline
post #5 of 5 Old 01-22-2014, 10:21 PM
Rodslinger's B1TCH
it's an open differential, that's how they work.
steve604 is offline
The Following User Says Thank You to steve604 For This Useful Post:
