Rear differential - Ford Powerstroke Diesel Forum
post #1 of 9 Old 01-20-2014, 12:15 PM Thread Starter
basicbajax's Avatar
Rear differential
I have uknowingly been driving around for over a year with a 285/16 and a 265/16 rear tire. What are the chances of this to cause me to have rear diff problems? Lately I have noticed during a turn I would get some vibration in the rear...now I sometimes get a dragging feeling that comes and goes. Could I have damaged my clutch packs in the rear end diff? How much nto repair?
I used to think high mileage was a bad thing, but its a badge of honor on my F250 Powerstroke.
basicbajax is offline
post #2 of 9 Old 01-20-2014, 09:41 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
not cheap to fix.
checked gear oil for shavings?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 9 Old 01-20-2014, 09:46 PM
Macon's Avatar
Drop pan, see if you have actual issues with the R&P. If you burned out the clutches, no biggy for normal use. Clutches are for posi-lock. If nothing is wrong, replace with tires that are the same size and press on with life.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 9 Old 01-21-2014, 02:08 AM
Quoted: 249 Post(s)
i think pulling the cover to see will definately be in order.
when was the gear oil last changed?
post #5 of 9 Old 01-21-2014, 04:55 AM Thread Starter
basicbajax's Avatar
I will be pulling the cover off real soon. As soon as the 08 style pan gets here. I could easily knock a hole in it by the looks of the rust...
Something is dragging the truck down real bad at times. Its not pulling to one side like a brake problem but It does feel like the brakes are on in the back. I dont know what to do...
post #6 of 9 Old 01-21-2014, 04:57 AM Thread Starter
basicbajax's Avatar
Gear oil has never been changed by me. I did top it off awhile back with what I had in the garage. I guess I need to start by seeing whats in the bottom of the diff pan and go from there.
post #7 of 9 Old 01-21-2014, 07:14 PM
Quoted: 249 Post(s)
could be a frozen slide pin causing the drag?
i had gold flakes in my gear oil when i changed it as well.
but when i pulled the cover again 5k miles later it was fine, had to play catch up on maintenance from the previous owner
post #8 of 9 Old 02-01-2014, 03:58 AM
I think the clutch packs are $170?
putzer is offline
post #9 of 9 Old 02-01-2014, 10:33 AM
Macon's Avatar
$300
TracLoc positraction Clutch Set for 3 Pinion Design for 10.5" Ford - YPKF10.5-PC
2002 F250 CCSB 4x4
Macon is offline
