Power steering noise, turn/braking? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-13-2014, 01:46 PM Thread Starter
Hey guys,
So I noticed lately that when I first warm the truck up and start to drive out of the neighborhood, I will turn and hear a whine. It's not consistant just a one time almost high pitch WOMP when I turn and then it stops. Also, it varies in loudness and does not always do it when I turn. It also happens sometimes when I brake as well sometimes but not as bad or as loud. Is this the power steering? I feel as it is but I do not know what the issue is. I have read that maybe I need a new pump? I replaced one of the power steering lines (very easy) a few months ago as I had a leak but have not had any issues until now. I will also like to add that there is trans fluid my mechanic put in there but It has been in there for almost 3 months and am now just having this issue. If you all could help me out because I truly have no idea but feel it is a simple fix I hope. Thanks in advance
dteal55 is offline
post #2 of 4 Old 05-10-2015, 10:50 PM
StrokinAlaska's Avatar
I've been told its the hydroboost. Bout 130ish to replace, not including labor. Mine does it on hard braking and most turns. Sounds like power steering is going out but the pump is good and has fluid. That's just what I was told though, I never fixed it
05-07 Front
GlowShift Gauges
AFE C.A.I
4" d.p
TS-Performance 6 Position Chip
Wicked Wheel 2
Coolingmist Stage 1
14lbs Nitrous Oxide
(2) 52" VisionX Xmitter Led bars
VisionX Cannon 4.7"
VisionX Cannon 6.7"
(2) 42" RaceSport Led bar
(4) VisionX Solo Soltice
(4) RaceSport Duallys
Hids
Alpine INE-S920HD
20 Speaker Rockford Fosgate Stereo System
3 Bulk Packs of Ballistic
Smoked Cab Lights, Fender Lights, SwitchBack Leds
Tint
2.8" Front leveling kit
StrokinAlaska is offline
post #3 of 4 Old 05-10-2015, 11:44 PM
hitmanheutel's Avatar
Just flush it first. There are vids on YouTube that show how. Pretty easy process. It made a world of difference on mine.
E99 CC LB DRW Banks intercooler:Big head gate; 6 position from Beans; 5"exhaust;transtar HD low stall billet converter; Valve body from cncfabrication; 4 line feed from cncfabrication; EBPV deleted; up pipes from riffraff; Isspro boost,fuel pressure,trans and EGT gauges; monitoring further with torque app; hutch and harpoon 230,xxx miles and climbing.
hitmanheutel is offline
post #4 of 4 Old 05-11-2015, 07:37 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
synthetic atf works even better.
the clunk is probably from the drag link needing grease or its worn out
blue99stroker is offline
