broken hub and missing parts - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-22-2013, 06:33 PM Thread Starter
irfreddy's Avatar
my pass hub was busted, only recovered an inner piece and a spring and broken bits. after taking it off, going from the other side im missing a snap ring and a locknut so far.
what is the order of parts after putting the bearing assy. on?(broken also)
can the parts im missing be used with warn hubs also, or do i need different nuts and washers?
irfreddy is offline
post #2 of 8 Old 12-23-2013, 06:02 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Here's what the parts look like (in an Auto Hub, you didn't say which you have) -> Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Not sure what LockNut you're referring to...
NoRalPh is offline
post #3 of 8 Old 12-23-2013, 07:18 PM Thread Starter
irfreddy's Avatar
not the hub. dont care about them. i have new warns in a box. im talking about the nut and snapring on the stub shaft. and anything else im missing.
THIS caused parts to be non existent.
irfreddy is offline
post #4 of 8 Old 12-29-2013, 06:29 AM
delta99's Avatar
Your shaft needs the 2 plastic hex shaped spacers, then the snap ring on it. Everything else is hub, you can just use all warn parts for that.
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #5 of 8 Old 12-29-2013, 05:07 PM
That is one nasty looking shaft!!
Not to steal the thread, but if the 2 spacers and the ring are all, what would cause the end of the shaft to be able to move up & down at the hub? Bad needle bearings? I have some play on both sides.
mkfan17 is offline
post #6 of 8 Old 12-30-2013, 05:03 AM
Quoted: 157 Post(s)
You're supposed to...
There's really not any support at the U-Joint from the Axle Tube and, with the hub out, only the Knuckle Seal holds the Stub Axle in place. So movement, even when everything's in place, isn't an indication of a problem (compare it to the other side or another truck and you'll see )
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
mkfan17 (01-07-2014)
post #7 of 8 Old 12-31-2013, 02:16 PM Thread Starter
irfreddy's Avatar
ended up getting all this:
Superduty D50 & D60 Hub Vacuum Seal
Super Duty Outer Axle Thrust Washer
Super Duty Thust Washer Kit
Axle Shaft Snap Ring, D60
plus the new stub, unit bearing, and hubs.
waiting for one more package to fix the truck finally
irfreddy is offline
post #8 of 8 Old 01-07-2014, 05:51 PM
Little bit of play on both sides, going to do the Needle bearing service next week but being prepared to do the u joints while i'm there!
mkfan17 is offline
