My first post. Need help with my '99 4x4. - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-16-2013, 04:15 PM Thread Starter
I hope I'm in the right spot for help. I need to find out if this '99 has made me crazy or if I'm not the only one. I recently purchased a '99 F250 7.3 4x4 6-speed manual. Keyword here "4x4". I have manual locking hubs on the front but I do not have a floor shifter, a dial to shift to four wheel drive "on the fly", or any light to indicate that I'm in 4x4. Did Ford make such a truck or did someone just put a front axle in and put factory 4x4 stickers on the truck and I'm a sucker? I tried locking the hubs today and they did not engage. I've heard of vacuum activated transfer cases but these are manual, as far as I can see. I'm not terribly new to diesels or four wheel drives but this one has me scratching my head. I've looked online and found the owners manual and that didn't help. My dad is a retired mechanic and could figure it out but he lives out of town and I want to handle this one on my own without the old man. Any help would be greatly appreciated.
ToddsBrother is offline
post #2 of 11 Old 12-16-2013, 04:26 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 1039 Post(s)
Feedback Score: 6 reviews
Well that is very odd. I guess you didn't make sure the 4X4 worked properly before you bought the truck. Any pics of the truck and interior you could share?
By the way, welcome to the ORG! I will move this thread to a different section that might get more attention for you.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #3 of 11 Old 12-16-2013, 04:40 PM
usteffenhagen's Avatar
It has no dial shifter either? But it's got a transfer case and a driveshaft going to the front axle?
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #4 of 11 Old 12-16-2013, 04:42 PM
when you turn the key to the on position all of the lights should light up on the cluster including 4x4 and 4x4 low as a self test. Check to make sure they are lighting up first as you could just have the bulbs out. Does it even have a transfer case ???
1fastblackz is offline
post #5 of 11 Old 12-16-2013, 05:34 PM Thread Starter
To try and answer the questions above.
1. It DOES have a front driveshaft going into the transfer case.
2. No, I did not check to see if the 4x4 worked when I bought it, which was the only thing I didn't check. I did take the guys word for it because I got it for a good price and assumed it wasn't perfect.
3. Indeed, no floor shifter and no dial to turn to "4Hi, 4Lo, 2H".
My first thought was as someone stated above, maybe fuses are blown that aren't showing "4x4" when I turn the key on BUT what puzzles me is that there's absolutely nothing on my dash that could be used to turn the 4wd to "2hi, 4lo, 4H" unless it's just "4x4". This is a first for me and I thought this was just something Ford tried for a short period because I can't find anything yet. I'm going from an easy to work on 92' IDI 7.3 to this computerized maze they call a powerstroke.
I'll have to post pics tomorrow for those that asked. Does anyone else have a '99 4x4?
post #6 of 11 Old 12-16-2013, 05:36 PM
RPM Tim's Avatar
As mentioned, look under the truck to see if it has a drive shaft to the front. If so, and no floor shifter then the shift on the fly switch should be on the dash between your gauge cluster and the radio.
Good luck
Well your post above doesn't sound good,, does your dash have a blank panel where the switch belongs?
http://www.ford-trucks.com/user_gall...id=10230&.jpg=
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #7 of 11 Old 12-16-2013, 05:43 PM
So it's got a T case and what not. No shifter of any kind.... Something's gotta give lol.... Get the VIN and run it by the dealership and they will tell you if it started life as a 2wd or not.... Still got the previous owner's number? Give him a call and see what's up with the mystery machine if you do
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 11 Old 12-16-2013, 05:52 PM Thread Starter
Good luck
When you told me that the switch should be on the dash between my cluster and the radio it hit me. The dial must have been knocked off because there is a round black plastic (what I thought was one of those cell phone holders glued to the dash) mount in the location. I say that because there are holes drilled in the dash in that area so I thought it was some kind of mount. It very well could be the back of the switch that was broken off. I hope that's the case because I feel like an idiot right now considering I joined the forum to ask this question. The indicator lights on my cluster not working were throwing me off even more.
So let's hold off in solving this puzzle until I can get underneath that dash to indeed make sure that's the switch mount on my dash. I promise I'll ask a better question next time.
post #9 of 11 Old 12-16-2013, 05:55 PM Thread Starter
lol, I agree that something's got to give. I kept telling myself "it's got to have one or the other". I just don't like my Ford dealership here in Athens, AL because they have not done good work for me in the past and I don't want to carry it there. I think I've got it figured out if you'll see my reply above.
post #10 of 11 Old 12-16-2013, 06:02 PM
no worries man we all have our moments trust me. I've had PLENTY of them. Just get a new switch, throw it in and enjoy the new rig!
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
