Power Steering Nightmares - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Corey@CNCFAB
post #1 of 5 Old 12-13-2013, 02:28 AM Thread Starter
LakiPolitis's Avatar
Guys...
I recently started having weak power steering (especially a dead stop, with a crew cab long bed I often have turn my wheels completely while not rolling just to not run over lesser, inferior vehicles). I've replaced my lines, my power steering pump, my hydra-boost, and power steering cooler, then bled the whole system. I'm still having the same problem. Weak power steering.
I'm running 35x12.5x20 Mickey Thompson (that are as bald as Bruce Willis - so I will be getting 38x13.5x20 Toyo Open Country M/Ts soon). I'm going to test out removing my steering stabilizers - they're older than hell - and seeing how that works (I'm on 9" of lift). Can you guys think of ANYTHING else that would be causing my power steering to be garbage?
LakiPolitis is offline
post #2 of 5 Old 12-13-2013, 10:23 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Time for hydro assist
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 5 Old 12-14-2013, 06:31 AM
RPM Tim's Avatar
I'm sure you've checked them along with everything else replaced, but I'll throw it out there anyway. Bushings, ends, or ball joints,,
I was aware that it needed ball joints and convinced that power steering pump was also going when I bought this truck. Whined and would become very (scary) stiff if hard on the brakes to make a turn, and near impossible to turn the wheel while stopped; tried bleeding and flushed the whole system with no improvement. Ended up replacing ball joints and an alignment before I put a pump on it and all of my steering issues went away
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #4 of 5 Old 12-14-2013, 01:43 PM
Quoted: 762 Post(s)
Just fyi, if you dont properly bleed the system they are a major PITA to get all the air out. Sometimes it can take 40-50 cycles to finally get that last air bubble out.
GeorgiaStrokin likes this.
Corey@CNCFAB is online now
post #5 of 5 Old 01-13-2014, 07:01 PM
codyd5051's Avatar
After replacing my tranny cooler it took over 50 cycles to bleed all air and now my power steering magically works better than when I bought the truck. Miracle.
2000 CCSB F350 7.3, Homemade BOF, Rebuilt trans w/ Trans Go Shift Kit and "HD" TC, In line trans filtration, Tru-Cool Max, Rotella 5W40, 4'' Exhaust, K&N intake (unfortunately), Ranch Hand Legend. 240k miles. Cooper M+S tires.
codyd5051 is offline
