7.3L Lock Up - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-12-2013, 06:55 PM Thread Starter
Question 7.3L Lock Up
2002 F350 SRW 4X4 Auto w/OD
First, does the torque converter even HAVE lock-up (or more appropriately, Torque Converter Clutch)???
I just got my vehicle 2 weeks ago, and finally got a chance to drive in other than rush hour and did the standard L/U test...
Everything warmed up, level road, steady speed in O/D then I lightly put on the brake with left foot. In a normal situation, you'd normally see a 200-300 RPM increase as the TCC comes out of L/U with the brake activation. On mine I don't see that, but wondered if the TCC was rigged to operate differently for the 7.3L...
If isn't getting L/U (and should) it's going to hurt my mileage some.
Any thoughts???
Thanks! Generok
Generok is offline
post #2 of 2 Old 01-05-2014, 01:59 PM
tman's Avatar
Any thoughts???
Thanks! Generok
How fast was you going? The tc will not stay locked in below 50mph while coasting and will always unlock no matter what speed your going when applying the brake. Which sucks when trying use the engine for braking assist. My truck has done this since it was brand new.I've installed a chip from sp diesel to help control the tc lock up by using the cruise control bottons to set what speed I want the tc to lock but it also makes the tranny shift alot firmer. The chip also can close the ebcv to give me a little more engine braking which I really like.(helps keep the brakes cooler going down hill)
Some members of this forum installed a switch to overide the ecm and lock the tc when ever they want. You can search "tc lock switch" in performance upgrade forum. Also there are some threads on "tc lock up" troubleshooting. Hope this helps answer your question.
My 2 favorite girls, My wife and my 2000 f250 XLT ECLB, All stock except for a 4"magna flow exhaust.sp diesel eb tc lock chip,and hypertech max energy econ programmer..
tman is offline
