ESOF electrical - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-08-2013, 10:48 AM Thread Starter
delta99's Avatar
ESOF electrical
I replaced my ford auto/manual hubs this summer with superwinch manual lock hubs. I used 4x4 for the first time yesterday, and shortly after switching to 4x4 high, my heater switched from vent to defrost. I obviously have a vacuum leak somewhere on the hub system. Since I no longer need vacuum to the hubs, I'd like to electrically disable it. I discovered under dash fuse 28 also powers the vacuum pump motor and cruise control and stuff, so I can't remove it. Under hood fuse 17 also powers the transfer case motor, so I can't remove that either. Will removing relays 40 and 41 cause any problems? Do these power anything else? Will I get any trouble codes? All I want is to keep the valve from actuating and pulling vacuum on the hubs.
2000 F250 Super Duty, 4x4, 7.3, 6 speed manual, 4" straight exhaust, 6637 air filter, superwinch hub locks, zoodad, foil delete, AIH delete, power pedal, autometer gauges, 2.5" leveling kit, 260,000
delta99 is offline
post #2 of 8 Old 12-08-2013, 11:30 AM Thread Starter
delta99's Avatar
I dug a little deeper, and I think the relays control the transfer case. Anyone know the electrical for this system?
delta99 is offline
post #3 of 8 Old 12-15-2013, 09:05 AM
I'm with you on this as I'm getting ready to install manual hubs on mine. I was going to ask the exact same question. Somebody has got to know?
50dan is offline
post #4 of 8 Old 12-15-2013, 10:03 AM
Not sure if this will help, but it seems to me the lines to the old vac hubs are probably just open to air now.
Try plugging those old lines?
Generok
Generok is offline
post #5 of 8 Old 12-15-2013, 10:48 AM Thread Starter
delta99's Avatar
It seems as though there is no way to do it besides unplugging the valve itself. I don't really want the connector just hanging out exposed, so I think I'll just disconnect and plug the vacuum line
delta99 is offline
post #6 of 8 Old 12-15-2013, 11:10 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Just plug the vaccum line at the hub
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 8 Old 12-15-2013, 01:22 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
You should be able to just unplug the electrical connector to the PVH solenoid (this is the solenoid that sends vacuum to the front hubs). This way it won't matter if you plug the vacuum lines or not because there will not be any vacuum going to them at all.
Here is the location of the solenoid:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #8 of 8 Old 02-15-2014, 04:22 PM
Colin7.3's Avatar
i just plugged the vaccum line at the solenoid.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
