Shifting Issues and ABS light on. - Ford Powerstroke Diesel Forum
post #1 of 1 Old 11-26-2013, 11:43 AM Thread Starter
Hello I just purchased a 99 f350 dually crew cab 2wd Powerstroke Auto. Under full throttle acceleration when it should shift it doesn't slip at all but instead shifts then downshifts then shifts again as if it can not make up its mind. All of this happening without lifting off of the accelerator. The ABS light is on all the time as well. my speedo reads fine though. Any help will be appreciated. Obviously more concerned about the trans then the ABS light.
Thanks!
Caleb
spooln1 is offline
