ABS Light - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-18-2013, 12:44 PM Thread Starter
ABS Light
Hello All;
I need some help with my 2000 Ford F-250 7.3 SD. Four weeks agon I replaced th wheel hubs with sensors. All was well until last week when the ABS light came on. Put code reader on and there were no codes thrown. Checked wheels, no dragging brakes. Checked front sensors .67 and .68 ohms. Tested output by spinning wheel, Rt .56 volts, lft .started at .9 then averaged out to .6 volts. Rear was .6. Started truck, ABS light went out as normal then after 25 yards of driving came on again. Turn off engine and let sit for a few minutes, restart light goes off and stays off until drive short distane and it comes on again. It consistently does this with the light staying on during driving. I'm now baffled. Any and all help would be appreciated. Thanks in advance!
GlenInIdaho is offline
post #2 of 9 Old 11-18-2013, 01:29 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Originally Posted by GlenInIdaho View Post
Hello All;
You have to have a special diagnostic reader to get codes from the abs. Most reputable shops have it and sometimes do it for free, that will help you start somewhere
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 9 Old 11-18-2013, 03:10 PM Thread Starter
Ok, that's good to know I was beginning to doubt by scanner. I have an appointment tomorrow a.m. at a local shop to do a scan. Thank you for the help.
post #4 of 9 Old 11-18-2013, 07:34 PM
Chapter Director
Quoted: 5 Post(s)
Yes sir its ridiculous it cant be integrated with the pcm but yea id guess it has something.to do with your install of sensors
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 9 Old 11-18-2013, 07:47 PM Thread Starter
I suppose I should have kept the old sensors, but didn't think there might be an issue. The truck has 163 thousand miles on it so I suppose these types of issues are going to spring up. Don't quite understand why it too four weeks to show up, but we'll find out in the morning, (I HOPE!!!) Thanks again
post #6 of 9 Old 11-19-2013, 01:39 PM Thread Starter
Here's an update on the ABS Light
The rear speed sensor was bad. Even though I tested it and found it to be producing 1+ volts, apparently it wasn't functioning properly. All's well now. Thanks for the help!
post #7 of 9 Old 11-19-2013, 02:02 PM
drivininidaho's Avatar
Quoted: 86 Post(s)
good to hear.. where are you from in idaho?
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #8 of 9 Old 11-19-2013, 03:58 PM Thread Starter
Thanks. Near Boise
post #9 of 9 Old 11-19-2013, 07:36 PM
Quoted: 86 Post(s)
nice, im down in Twin.
Lyndel
'04 F25 SD CCSB
