HELP STUCK IN A DITCH - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-02-2013, 04:57 PM Thread Starter
causethechicksdigit's Avatar
Exclamation HELP STUCK IN A DITCH
Hey guys,
Today i backed into the back ditch at the house to unload some stuff out of the bed of the truck and normally i use 4 wheel to get out, today i locked my hubs in and neither of my front tires turned, so i ended up getting out in 2 wheel after a bit.
After i got to the barn i got the truck up in the air and tried the 4 wheel again, and found out that the front drive shaft is turning, then as I looked further out i found that the driver side outer axle shaft is turning but not the tire, and the passenger side outer axle shaft isnt turning and neither is the tire.
I checked both lockers and they seemed to be working fine. Im thinking there may be a broken axle shaft or something inside. Has anyone had this before or know of a way to go about solving this without breaking into the axle super deep?
Thanks
Late 99 7.3L Stroke, 4in Turbo Back with 6in Stack, 75&140 HP 2 Position Chip, Boost Fooler, Foil Delete, GDS Fuel Spring, Intake, WW,4 inch suspension lift with drop pitman and drop track bar bracket, 35x12.5x16" on stock rims
causethechicksdigit is offline
post #2 of 10 Old 11-02-2013, 05:19 PM
Heavy_GD's Avatar
Quoted: 1436 Post(s)
Feedback Score: 3 reviews
Ford OEM hubs? Trash em
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #3 of 10 Old 11-02-2013, 05:24 PM Thread Starter
Would failed hubs cause the axle shafts to not spin though
post #4 of 10 Old 11-02-2013, 05:43 PM
Heavy_GD's Avatar
If I read that right, both shafts turned but the wheels didnt.
If so that isolates the hubs.
The front hubs will mechanically disconnect the stub shafts from the wheels. Failed or unlocked hubs means no power to the wheels, locked hubs means the wheels are powered.
GD
Heavy_GD is offline
post #5 of 10 Old 11-02-2013, 05:45 PM Thread Starter
Sorry if I wrote it wrong but no only one axle shaft is turning and neither tire
post #6 of 10 Old 11-02-2013, 05:49 PM
Heavy_GD's Avatar
I would think only one would spin if dont have a front locker, I still think its the hubs failing.
But I'm no tech.
GD
Heavy_GD is offline
post #7 of 10 Old 11-02-2013, 06:02 PM
KillNThrill24's Avatar
Sounds to me like hub failure would be a probable cause...
2000 F350 Lariat CC LB, 00 Mustang GT, 01 turbo Cobra
KillNThrill24 is offline
post #8 of 10 Old 11-02-2013, 06:13 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 56 Post(s)
Feedback Score: 7 reviews
hub failure. if you have a factory diff (open) power is only applies to the wheel with the lease resistance. helps you turn in 4wd.
God bless America, the Constitution and the Second Amendment.
powerstrokeshellback is offline
post #9 of 10 Old 11-03-2013, 02:19 AM Thread Starter
Thanks for all the help guys,
I spent about 4 hrs last night with the hubs cleaning and oiling them and it's working again so looks like I'm going to buy new hubs to prevent this again hopefully
post #10 of 10 Old 11-03-2013, 04:56 AM
usnavyad's Avatar
Yep those axels basically just float and slide in very easy to take out but founds like the hubs to me!
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
