HUB SEAL ? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-24-2013, 09:43 AM Thread Starter
HUB SEAL ?
Searched and couldn't find any info on this. Are the Hub seals absolutely necessary. I replaced the factory locking hubs with milemarker stainless and just bought new hub/bearing assemblies and just didn't want to fork over $50 a pop for the seals if not needed?
sloppydawg71 is offline
post #2 of 6 Old 10-24-2013, 09:57 AM
ZMANN's Avatar
Quoted: 1907 Post(s)
they can be since they keep moisture/ dirt out
but you don't need to change them if they look decent and seal ok
make sure you block the vacuum port from the PVH solenoid since it's no longer needed
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #3 of 6 Old 10-24-2013, 09:59 AM Thread Starter
so they are needed?
just to add they were destroyed when I removed them.
post #4 of 6 Old 10-24-2013, 10:01 AM
ZMANN's Avatar
you can't run without them unless you want to chance trash the new locking hubs and the spindle bearing on the unit bearing
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #5 of 6 Old 10-24-2013, 10:02 AM Thread Starter
thanks man thats what I needed to know...back to the parts store.
post #6 of 6 Old 10-24-2013, 10:04 AM
ZMANN's Avatar
it also takes a special tool to insert into the knuckle or you can make one ( google ) but be careful because the DIY pipe one doesn't set it to depth like the proper tool
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
