Highway rumbling noise - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-10-2013, 06:02 PM Thread Starter
I have a 2000 Excursion 7.3. I am having a weird vibration noise which only occurs at 52-55mph and up, most often at light to no throttle. When it occurs you can often throttle it more to get rid of the noise. It is like a rumble strip noise.
I have already replaced both stub shafts, all front seals, both wheel bearings, e.t.c, the whole front end. All u-joints are new as well.
I was thinking it might be the rear driveshaft angle (but didn't have any problems before), or the torque converter.
Any thoughts?
Thanks,
Ben
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #2 of 7 Old 10-10-2013, 08:14 PM
Macon's Avatar
Broken spring? You replaced all the u-joints... Did you witness mark the shafts and get them back on the same? Have you balanced the tires lately? Does it change with speed or RPM? There is a difference. Speed means you're looking in the right area, RPM means you're not. Try the same RPM at a lower speed to see if you notice the same vibration (maybe attenuated some, but there).
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 7 Old 10-11-2013, 01:48 AM Thread Starter
Yes I marked all the shaft parts and installed them in the same order. Tires where balanced and rotated to see if noise changes. The noise seems to be engine load dependent and only noticeable at speeds above 50mph.
326RWHP @ 731RWTQ.
572ysc is offline
post #4 of 7 Old 10-11-2013, 01:54 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Lots of Super Dutys do this... Most do it at 42-45 mph, not sure why and a lot of guys have changed several parts without any luck in fixing the problem. Someone once it has to do with the road giving the suspension a perfect harmonic imbalance to cause the problem... Let us know if you figure it out. Only thing I tried was replacing my unjointed and carrier bearing but still have the same thing.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 7 Old 10-11-2013, 02:37 AM Thread Starter
Yea it is just soo annoying driving with this noise sometimes!!!
326RWHP @ 731RWTQ.
572ysc is offline
post #6 of 7 Old 10-11-2013, 02:40 AM
Quoted: 8 Post(s)
Is it a noise or a vibration?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 7 Old 10-11-2013, 02:33 PM Thread Starter
Its more of a noise, but sometimes you can feel it. Front sway bar and driveshaft have already been removed but the problem remains.
326RWHP @ 731RWTQ.
572ysc is offline
