Vibes at 40 mph - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-10-2013, 10:42 AM Thread Starter
Vibes at 40 mph
I have been trying to chase down a pretty good vibration at 40mph. I initially attributed this to my tires, they were well worn, and needed to be replaced.
I put some new Dura Grapplers on it, and still have the vibration. The vibration feels almost like wheel hop. The shop that did the tires is very good, and I have never had problems with their balancing job in the past.
I have checked to make sure that my front hubs are disengaging, The only other thing that I can think is maybe my rear drive line is out of balance? My truck is a 01 extended cab long bed with a carrier bearing.
Any ideas?
Thanks for your time
))--SLIVER-->
SLIVER300WSM is offline
post #2 of 4 Old 09-11-2013, 09:31 AM
Powerstroke Junkie
NCHornet's Avatar
Is it lifted? If so has the carrier bearing been shimmed correctly? I would get it off the ground and get things spinning and see if you can track it down.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #3 of 4 Old 09-12-2013, 11:42 AM Thread Starter
The truck has 208k on the clock. It is leveled in the front, and has an ad-a-leaf in the rear. It has been this way for the entire time I've owned it (2 years), and the vibes did not start until approx 3k miles ago. I may have to take it to a DL shop to see if they notice anything wrong.
))--SLIVER-->
post #4 of 4 Old 09-13-2013, 08:21 AM
Powerstroke Junkie
NCHornet's Avatar
Time to get it up on a lift and it should be obvious where it is coming from.
NCH
Ford AIS/ BTM, FTVB
KMC Wheels x 4
NCHornet is offline
